Frontera Technical Support • View topic - Fronty4x4spares...Quality Used Parts, rapid delivery.
Leave it with me Rob....I will see what we have here
HI Guys,
Can I add a set of rear seat belts ( Left and right side) for a Fronty B 2001 SWB to my list of parts.
Did I mention I am after a B'series loom ( complete as possible / full )?
Thanks
John
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
Hi Greg
Hope is all well with you, the snow has disappeared here due to all the warm weather and RAIN you sent over. It has been the warmest March on record here 10 degrees so hope spring is around the corner. That means time to work on the Frontera again, Greg can you help me, I am looking for a Steering box (gear, the one with the 3 bolts and sits front right hand side) mine has been clunking on and of for a while now, but has really got bad. Also do you have a front bumper, my wife thought she could drive through some snow but in the snow was a concrete post, Whoops!
Hope you can help me once again, looking forward to hearing from you
Ray
P.S. I tried to PM you but for some reason it's still stuck in the outbox.
raytelford
Modifications: Also have 2.2 DTI 3dr Sport RS 2004
That's because the lazy bugger hasn't read his messages recently. :oh yer: It will only go from your outbox when he clicks on to read it. :thumbup:
Regards Bobster.
Just replied... :oops: :oops: :oops:
i still need indicater please i pmd you my postcode ,,,,,,cheers
kidmachine
Registration Year: 1992/J
Vehicle Name: kidmachine
Hi Greg
Good to hear your venture is working for you, I can see on the web site the number of requests for parts. I like the Frontera that's why I want to keep it going, I know its 11 years old but it’s perfect in the winter and for my caravan in the summer, plus all the kids at school think it’s cool to have a right hand drive.
OK Down to business, the box I refer to is the one at the end of the steering column that then connects to the steering rack, like a "V" shape drive, it is secured with 3 long bolts to chassis.
http://www.hollanderparts.com/UsedAutoP ... gear%20box
I only need the skin of the bumper. Theirs a guy in Sevenoaks on e bay, he's quoting £55 delivery.
http://www.ebay.co.uk/itm/Genuine-OEM-V ... 2c7928585e
One more request, rear left hand brake caliper (the fixed/bolted to axle part not complete caliper) I have sheared a bolt while changing pads (the pin part of the bolt ceased in) its running on one bolt. Plus a couple of bolts.
Many thanks
Ray
raytelford
can you get radiator for a 2.2 petrol 2000 frontera lwb if so how much
griegwwr
Rumour has it the gear box mounting crossmember from an A Series 2.2i will fit the 2.8 and line up okay to the gearbox mount when the 2.8 gearbox has been moved forward as part of the Trooper Flywheel/DMF Flywheel change and then negates having to drill the original 2.8 crossmember.
Is this correct and if so do you have one available in some dark corner of the yard please?
do u have a ecu with keys for fronty 2003 dti pm me please if u have one
steven
Registration Year: 2002/52
Vehicle Name: THE TRUCK
Modifications: DECAT STAINLESS STEEL RIGHT THROUGH TWIN PIPE ON END ,WIND DEFLECTORS, PRIVATE PLATE LIMO BLACK REAR TINTS,LED SIDE LIGHTS AND NUMBER PLATE LIGHTS.
ALL DASH LIGHTS IN LED WHITE.HID headlights 12v feed to boot with a power inverter. also fitted sub & amp.
Greg have you got a carrier and slider pins for the OSF brakes my caliper is fine so don`t need that bit price with postage to Liverpool please Greg
thanks Mike
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Hiya...we only sell them complete unfortunately, the sliders being the bit that condemns more of them that piston issues...
Well if my front diff on the 2.0 coiler has gone how much for one delivered
What ratio is yours andy???
Don't know haven't checked that out yet :lol: because I thought all the 2.0 were the same
all 2.0 coilers are 5.13... if it is a leafer it coule be 5.13 or 4.88
