// Frontera Technical Support • View topic - Annual Meet Questions
Re: Annual Meet Questions
Postby Fatbaz on Tue Apr 24, 2012 1:14 pm
Forgive me for butting in, for those that haven't been before. Once you've turned off of the main road and are on the track on to the site you pass through a parking area (pay and play day parking), the track then goes around to the left then right then left (on the right hander you will see the course in over on your left), keep following the track, keeping the course on your left, you will arrive at a gathering area where you will see a marque. Last year the marque was used as the marshalling point for signing in on arrival. Don't know if the same is happening again this year though.
The 2 gates that Drifty makes reference to are there for safety reasons, you will drive past them on your way in, one on either side of the track. When the track has right of way the gates close off the link track to the open course and the woods. To drive from the open course to the woods and back you move/open the gates to block the track (operates like a gated level crossing). Once you've crossed the track you put the gates back.
I'll get me coat!!!!!!!!!
Regards
Stuart :oops:
Fatbaz
Modifications: Suspension lift curtesy of TJM +2 springs
Hankook RT03 285/75R16
50mm body lift
Custom built winch bumper
Trooper axles front and rear LSD
LED head lamp bulbs
Return to Fog Annual Meet - 2012
