overheating problems
overheating problems by geoffwood on Fri Oct 16, 2015 3:30 pm
Hi I have recently bought my second Frontera the problem I have is overheating, its a bit strange really sometimes its ok but when you start to go uphill the temp' starts to rise I have replaced the thermostat which didn't help when I pull over to let the engine cool down the center part of the rad is cold I took the rad off to replace it but when I put boiling water into it from the kettle the rad gets hot all over if any one as any idea's that would be great cheers Geoff I forgot to say the frontera is a 3.2 v6 03 model
geoffwood
Re: overheating problems by robbie on Fri Oct 16, 2015 3:37 pm
Check the fan is working as it should.
Cold it should turn easy by hand.
When hot it should be very stiff or not turn by hand.
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: overheating problems by hipo1024 on Fri Oct 16, 2015 7:22 pm
Also worth checking the water pump? If it has plastic impellers then they can break off and cause poor flow
Re: overheating problems by Big Dav on Fri Oct 16, 2015 8:10 pm
Worth considering an air lock?
I know the 2.0 engines are horrendous to get all the bubbles out....1st and 2nd attempts.
