Frontera Technical Support • View topic - HGV Sat Nav
HGV Sat Nav
HGV Sat Nav by Drift on Tue Oct 08, 2013 6:06 pm
What is a reliable and relatively cheap HGV sat nav?
I will be using a three axeled Scania rigid but I will be carrying some hi masted Reach and counterbalance fork lift trucks and its quite a high bed on the truck.
Added to this as its the only rigid I will be going to places the artic trucks find it difficult to get too, but with the danger of low tight bridges :roll: .
Re: HGV Sat Nav by Wilberforce on Tue Oct 08, 2013 6:10 pm
I'll have a dig through the stack of Trucking and Truck & Driver mags at work, Ste.
They tend to do reviews of HGV oriented kit reasonably frequently.
The one I was always eyeing was the Snooper Truckmate range, but they start from about £200 IIRC. Nice and big screen, and properly designed for trucks.
Re: HGV Sat Nav by Drift on Tue Oct 08, 2013 6:19 pm
Cheers Jim, i llooked at them and they are good but until the extra money comes in its a tad expensive unless I forgo new tyres.
Re: HGV Sat Nav by Wilberforce on Tue Oct 08, 2013 6:38 pm
Depends how badly you want the new tyres I guess :drive:
Re: HGV Sat Nav by Drift on Tue Oct 08, 2013 6:43 pm
Quite :oops: I have been working on them for months and now with my pay rise :lol:
How are these? (I know very cheap) but just want a valued opinion :wink:
http://www.ebay.co.uk/itm/7-TRUCK-COACH ... 27d8fb7c23
Re: HGV Sat Nav by snapper on Tue Oct 08, 2013 7:02 pm
Cheap enough Ste, and reading through the ad it seemed okay until I reached this bit, and I quote... "please note that the maps used on some of the units have a small bug with heights, when inputting the height please put in 2.6 x2" :think:
I suppose, if you just attack the bridge at a fair rate of knots, close eyes in the last couple of mtrs and get the prayer beads out .....might work, def fit the second time, just gotta line up on the groove that's neatly sliced under the bridge... :oh yer:
On the other hand you could just take a saw to the masts or lay the trucks on their sides... It'd fit then .... :thumbup:
PS, I used to drive a truck :shock: I don't now ...
Re: HGV Sat Nav by andytats on Tue Oct 08, 2013 7:26 pm
Real truck drivers use a good old paper map :lol:
Re: HGV Sat Nav by Drift on Tue Oct 08, 2013 7:31 pm
The sat nav is an aid to use after the motorway but not gospel :lol:
Its just the variety of heights I will be carrying and the areas they will be going, pretty much country wide.
Re: HGV Sat Nav by rseaville on Tue Oct 08, 2013 7:50 pm
Navfree on the iphone changes the routes for anything from walking to artics and it's free :D As for the bridges the lower ones tend to be very well signed.
rseaville
Vehicle Name: Tera
Skype Username: rseaville
Re: HGV Sat Nav by Drift on Tue Oct 08, 2013 7:54 pm
I am on android :lol: :lol:
Re: HGV Sat Nav by Big Dav on Tue Oct 08, 2013 10:24 pm
A bit time consuming but could you street google, dropping down to road level to get an indication.
I'm not a truck driver but any time I'm venturing
to pastures new I have a gander to get the lay of the land especially for unusual junctions.
Re: HGV Sat Nav by Drift on Wed Oct 09, 2013 6:29 am
Cheers David, but that's a bit time consuming as the load can change with a phone call and there will could be three drops and pick ups a day.
Re: HGV Sat Nav by andytats on Wed Oct 09, 2013 7:48 am
I've just found this so haven't read up on it yep. Have a look to see if it helps
http://www.hgvsolutions.com/buy_procab.htm
Re: HGV Sat Nav by andytats on Wed Oct 09, 2013 11:06 am
What about one of those
http://bit.ly/16lxsFZ
Re: HGV Sat Nav by andytats on Thu Oct 10, 2013 7:18 pm
I've just bought this one. http://bit.ly/1ad6Wf8
once I've received it and used it for a day or two I'll let you know if it's any good
Re: HGV Sat Nav by Drift on Thu Oct 10, 2013 7:44 pm
Cheers Andy :thumbup:
Re: HGV Sat Nav by Wilberforce on Thu Oct 10, 2013 8:19 pm
Re: HGV Sat Nav by Drift on Fri Oct 11, 2013 8:17 pm
I borrowed an older Snooper earlier in the week and it worked well I thought so I nicked Lee's credit card and plumbed for this as I will likely be kicking off full time in the latter half of next week.
http://shop.snooperdirect.com/product2100186.html
Oh and now she sussed out my theft my tyres are on hold :lol: :lol:
Re: HGV Sat Nav by Wilberforce on Fri Oct 11, 2013 8:49 pm
I doubt you'll regret it mate. Well, pinching OIC,HF credit card perhaps.
They are good kit and the extras and updates you're getting will serve you well.
Re: HGV Sat Nav by Drift on Fri Oct 11, 2013 9:01 pm
Cheers Jim, I didnt go for the higher version not through fear of death but the features on it like bluetooth and stuff where not needed as the cab has bluetooth anyway and all other functions would be covered by my tablet especially as I may be doing one or two overnighters a week mainly around Shrewsbury, so movies and ti'nternet is covered :lol:
