Memory map
Memory map by colley on Fri Feb 15, 2013 8:18 pm
This is a long shot but you never no :|
Does anyone have maps for morocco using memory map?? Memory map them selves don't do maps however I have heard that there is another way of uploading maps??
Anyone had any experience of this??
Any info would be very helpful :wink:
Re: Memory map by Trugga on Fri Feb 15, 2013 11:21 pm
I just entered your search criteria into Google and it came up with a few suggestions: https://www.google.co.uk/#hl=en&sugexp= ... 36&bih=751
If you can't mind a map electronically, I know in the past I've spent many an hour screen capturing on-line maps and stitching them together into a larger file. I played about a little with calibration, but don't think I got too far.
Re: Memory map by Drift on Fri Feb 15, 2013 11:35 pm
I would join an overland forum, they would have advice on this. :wink:
Re: Memory map by colley on Sat Feb 16, 2013 12:31 am
Lawrence that's what i have been advised to do :? sounds complicated as you need to calibrate the maps afterwards which sounds even more complicated :?
Ste already on it but been advised to do the above.
I have been advised there is company in the states that sell the maps that work with memory map but they are meant to be ££££££
Might give them a call to find out :wink:
Re: Memory map by Alfie on Sat Feb 16, 2013 12:24 pm
Try some of the motor cycle trail riding sites. I've seen some with maps for Morroco and Algeria and rod books for some of the old paris dakaar raleigh stages
Vehicle Name: Dino
