Android Geek needed
Android Geek needed by Rich on Fri Jan 25, 2013 8:35 pm
I have got a 10inch tablet running on android 4.0.4. The thing died last week. I had let the battery run flat during an update :oops: i had to get in touch with the company that make them. They sent me out a micro sd card with the FW on it which got the tablet working. But now the usb is not working on it.
It's got a micro usb and a normal usb port it's still connecting to the laptop via the micro usb port. But the normal sized one is not recognizing a memory stick or usb keyboard/mouse they connected before the tablet crashed. There is no damage to the usb ports anyone got an idea how to fix this problem.
The tablet is a ergoelectronics GoTab GBT1040r model Number T10A
Re: Android Geek needed by Drift on Fri Jan 25, 2013 10:36 pm
Is there an option for a soft reset? its usually a hole you stick a cocktail stick in or something like that. This should be like booting up but a bit better and it may them read the aux ports.
Re: Android Geek needed by Rich on Fri Jan 25, 2013 11:00 pm
thought about that ste they do put a reset button on the tablet but it does Fook all :D :D :D according to gotab its not a reset button :shock: :shock:
Re: Android Geek needed by Drift on Sat Jan 26, 2013 12:20 am
Whats it for then :? :lol:
Are all the updates installed?
I had a job getting the Sony S to see a memory card but updated it and it saw it.
Re: Android Geek needed by Gazeddy on Sat Jan 26, 2013 10:24 am
update to latest then do a factory reset
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: Android Geek needed by Rich on Sat Jan 26, 2013 11:31 am
i have got the latest software/Firmware as supplied by the company that make the tablet they sent it out on a micro sd card.
Re: Android Geek needed by Gazeddy on Sat Jan 26, 2013 11:36 am
go into the settings menu and down the bottom there should be an option for back up and reset
go into there and select factory data reset
Gazeddy
Re: Android Geek needed by Rich on Sat Jan 26, 2013 12:18 pm
all ready tried that m8
the tablet was not booting up so the manufacturers sent out the FW on a memory card. You have to put the card in the slot turn on the tablet let it do it's stuff That worked
and the tablet booted up. But the USB OTG is not working :cry:
