Laptop for the bin?
Laptop for the bin? by jimmybhoy on Wed Sep 12, 2012 11:59 pm
My samsung R530 running windows 7 o/s has had a low battery issue of late. I was on it the other night emailing an estimate for work, when i pulled the power lead out. The machine shut down as if there was no power. I tried to reboot. After 2 days i can get it on, everything looks ok but with very small icons. The search bar is also black instead of white. I cannot click on anything as its unresponsive. Anyone have any suggestions, im on the wifes for the Mo, no doubt she will start the yadda yadda just shortly wanting it back. Not having my own laptoppamabob ,will cause me medical problems........ sore ears!
jimmybhoy
Registration Year: 2004/04
Re: Laptop for the bin? by snapper on Thu Sep 13, 2012 8:11 pm
Knacked battery, it was running on the main lead only. May even be a flat cmos battery as well.
Try starting it in 'safe mode' (sounds like it may already be in that though) if you can try doing a reset with the system restore, if that fails and you have the wherwithall then take HDD out and piggy it onto another machine as a slave drive and get your data off it. Then stick it back in, put the recovery disk in and re-boot with that. It will overwrite everything but with luck sort it.
Re: Laptop for the bin? by AskDean on Thu Sep 13, 2012 8:59 pm
press f8 on boot go into safe mode and click repair
AskDean
Skype Username: askdean
Re: Laptop for the bin? by worldclassmusician on Thu Sep 13, 2012 10:22 pm
If it's booting up and running but you have problems like it's slow, the task bar is the wrong colour, stuff like that, but it's working nonetheless then it sounds like your hardware is ok, and that it's a software problem.
I've not run a PC for a while, so have no idea about Windows 7, but if you have a boot disc/dvd, reinstall windows. It does sound like you need a new battery though. Try the reinstall before splashing out on a battery.
worldclassmusician
Vehicle Name: Rhino
Modifications: Re-painted with Bed Liner
New tank carrier
Mud tyres
Black steel wheels
Bucket Seats
Bull bars
