security centres been deactavited
security centres been deactavited by fogman on Tue Aug 07, 2012 11:38 am
my girlfriends sons laptop had a virus ( the name escapes me at the moment but it was something like security premium gold ) i booted it in safe mode, downloaded malwarebytes & ran a scan, the fake security pop up has gone & the laptop runs ok except for the security centre has been turned off & cant be turned back on, the a/v has obviously been disabled as well.
Re: security centres been deactavited by RatCav on Tue Aug 07, 2012 12:12 pm
Restart in safe mode and then manually run your anti-virus .... and tell him not to look a pron sites :D
Re: security centres been deactavited by fogman on Tue Aug 07, 2012 1:03 pm
i have i have & i have :roll:
ive been googling it, its suggested to enter services scroll down to security centre & manually change the settings there but the security centre isnt even listed within services, ive checked on mine & it should be listed but so for some reason its dissapeared :shock:
Re: security centres been deactavited by mega-fronty on Tue Aug 07, 2012 3:36 pm
best to reformat it i think or if you have it re-install the OP
Buggy drivers do it with Helmets on........
mega-fronty
Vehicle Name: Barricade
Modifications: Suzuki Vitara
200TDI engine
32" Bronco Dirt Devils
Re: security centres been deactavited by BoxCleva on Tue Aug 07, 2012 3:54 pm
Had this on clients PC's loads of times.
It can be removed , but it's a fiddly pain in the proverbial.
Here's a good tutorial.
http://www.fakealerts.com/rogue-antispy ... n-545.html
Re: security centres been deactavited by fogman on Tue Aug 07, 2012 4:45 pm
your not wrong there bc
did all the above then did a file & disc check which failed to repair it so i then returned it to an earlier restore point, then re installed malewarebytes ( the earlier restore point unistalled it of course :? ) then scanned it again to make sure its clean & hey presto many hours later its all sorted, my blood pressure has of course has gone through the roof :shock:
what a cuffle thanks guys :wink:
Re: security centres been deactavited by vauxsqueeks on Tue Aug 07, 2012 9:01 pm
Hi,
Glad its sorted now, but for reference you can download the stinger tool from McAfee ( free tool) that is geared up for FakeAlert type infections and is updated at least daily.
Http://stinger.mcafee.com
Finding suspicious files for review by McAfee
Http://getsusp.mcafee.com
System restore was a great concept, but it can also restore viruses back to the PC after the AV has deleted it!
Advice would be to disable it, backup often & update not only your operating system regularly, antivirus updates and applications like adobe, flash, Java etc.
Because the operating system is harder to break into through the front door so to speak, the virus writers find an exploit in an application like Internet Explorer/Firefox etc and use that to get higher privaleges on the computer.
Its easier to break into the house and steel the car keys than to try and bypass the security on the car directly..
Still.. glad its sorted.
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
