Frontera Technical Support • View topic - mm tracker vs memory map on android
mm tracker vs memory map on android by jontera on Fri May 11, 2012 11:13 pm
Been a little bit bored at work tonight so i decided to have a search around the app store for my samsung galaxy.
found and downloaded both MM tracker and the official Memory Map apps..both free
the memory map come with a basemap that has limited zoomability and detail, and the MM tracker comes with no maps at all..
now question time..
to use the Memory Map app, do I have to have it also installed on the home PC to download the relevent map files to the sd card?..even if i don't want to create routes etc..also if I somehow managed to "aquire" some maps that are of the older file type is there anyway of converting them on the cheap?...ie free.
for the MM tracker, I think that i just use the said "aquired" maps without converting..surely it'snot that simpple?
also I don't understand the 25k,50k bits about the maps. does one have more detail or does it mean a bigger map?..therefore alot more card space..can these be cut down to cover just the area your in? for instance just the north of Wales rather than the whole of it..
edit* which one is the preffered choice of FOG and why?
keep it simple for me please..
Re: mm tracker vs memory map on android by Drift on Fri May 11, 2012 11:18 pm
John, do you have my phone number :wave:
Re: mm tracker vs memory map on android by Drift on Fri May 11, 2012 11:21 pm
With the tracker for Android you can transfer maps from memory map from the pc to the device and the MM Tracker will read them almost the same as using the original windows format they where designed for :thumbup:
Re: mm tracker vs memory map on android by snapper on Sat May 12, 2012 1:26 am
Not quite the same bit of kit but I dug an old HP ipaq hx4700 out the cupboard (it'd been there somewhat dead for the last 2 years) for the annual, a couple of new batteries and it even worked.
I then downloaded mm onto the pc from the mm site and transfered it from that installation onto the 4700. As for maps, once I got the thing talking to the lappy it was a simple task of loading the map files straight onto it. It's now running quite happily with the maps on it (4Gb CF Card) and blue toothing to the old tomtom gps unit. Out of interest, anyone know whats the biggest CF card these things can talk to?
Re: mm tracker vs memory map on android by Munfred on Sat May 12, 2012 8:16 pm
Memory map allows you to use pinch zoom. Tracker doesnt. Only reason i use it more.
Munfred
Re: mm tracker vs memory map on android by jontera on Sat May 12, 2012 9:59 pm
Re: mm tracker vs memory map on android by bobbinsjob on Wed May 16, 2012 8:39 pm
does anyone know if MM is gonna be released for Windows Phone at all?
Re: mm tracker vs memory map on android by Drift on Wed May 16, 2012 8:42 pm
It already works on windows, I was running it on a o2 orbit years ago :thumbup:
Re: mm tracker vs memory map on android by bobbinsjob on Wed May 16, 2012 8:43 pm
thats on windows mobile, not WP7 though mate :(
Re: mm tracker vs memory map on android by Drift on Wed May 16, 2012 9:03 pm
Bummer
Ive just looke on the MM site and no mention of Windows, looks like they have dropped them :shock:
Re: mm tracker vs memory map on android by Drift on Wed May 16, 2012 9:06 pm
Re: mm tracker vs memory map on android by bobbinsjob on Wed May 16, 2012 9:35 pm
tossers :roll: :roll:
Re: mm tracker vs memory map on android by Drift on Wed May 16, 2012 9:37 pm
:lol: :lol: :lol:
Android is the way forward in mobile...its taste sensation :lol: :lol:
