SAT NAV problem
SAT NAV problem by Bearcat on Thu Mar 01, 2012 8:36 pm
After the last update my TOM-TOM Go 750 Live will not switch on normally, only after holding down the on/off button for 15 secs (reset) will the start screen appear, and that's as far as it goes, the touch screen does not respond. Any help appreciated
Bearcat
Registration Year: 1994/M
Vehicle Name: Cat-Cat
Modifications: No Mods
Re: SAT NAV problem by James Bass on Thu Mar 01, 2012 9:10 pm
Can't you revert to a previous update, like you can on a PC?
Re: SAT NAV problem by Bearcat on Thu Mar 01, 2012 9:30 pm
Not sure, maybe when connected to Tom-Tom Home on the computer, I will try it, Thanks,
Bearcat
Re: SAT NAV problem by alsavs on Thu Mar 01, 2012 9:34 pm
Hi Bearcat i have no answer to your problem but this site might be of help. http://www.pocketgpsworld.com
Alan.
alsavs
Registration Year: 1992/K
Modifications: Non as yet
Re: SAT NAV problem by Big Dav on Thu Mar 01, 2012 10:10 pm
There is the reset facility within the menu's but if your touch-screen is goosed you may not be able to access it. Resetting usually wipes all updates, favourites etc - as I found out to my irritation.
Re: SAT NAV problem by Bearcat on Fri Mar 02, 2012 8:43 pm
Thanks guys, I have found a Tom-Tom forum, TOM- TOM Discussion, not sure how it works yet, I'm not to hot on electronic gagets.
Bearcat
Re: SAT NAV problem by snapper on Fri Mar 02, 2012 8:46 pm
Ring up TomTom, if it's under 2 years (might be 1 year) and you still have the recipt they will change it. They will want you to try re-loading the software, or they did with mine last year.
Re: SAT NAV problem by Bearcat on Sat Mar 03, 2012 11:00 pm
Thanks for the help,
Afraid it's over 2 years old ,
After looking on Tom-Tom forum and pocketgpsworld I find this is a common problem since the latest Tom-Tom updates,and there is no solution so far.
Bearcat
Re: SAT NAV problem by john (smifffy) on Sun Mar 04, 2012 12:14 am
try plugging it in to your pc an put the saved (before update )files back on it :drink:
Re: SAT NAV problem by Bearcat on Mon May 21, 2012 8:53 pm
Tom-Tom Sat Nav now working, found a fix on a forum, involved removing everything from the device and then updating, the cause was a faulty map update in February. Thanks guys for your help.
Bearcat
