Frontera Technical Support • View topic - Memory Map for Android - Beta version FOC
Memory Map for Android - Beta version FOC by stevd on Mon Dec 19, 2011 6:20 pm
Hi all,
I came across this the other day and thought it maybe of use for some of you, its a free beta version of the new memory map for android. I have just loaded it on my Galaxy s2 and it seems to work great. Lets you load and create overlays.
Its a zip file so you just have to unzip on your home computer, copy the .apk file over to your phones storage and then run the file from your phones file managing software. Any maps you have, just copy them over to the specified folder, and bobs your uncle...it works.
I dont know if it will be free when they release it so it maybe worth getting the beta version of it. I remember on my old iPhone it was an expensive app for the full version.
S
stevd
3.5" wind up on front
pro Comp Shocks
Side step removal
Bonet Guard
A fair amount of scratches
Lots of rust to add character
16" alloys from an A Series
Silicone vac pipes
Re: Memory Map for Android - Beta version FOC by stevd on Mon Dec 19, 2011 6:24 pm
stevd
pro Comp Shocks
Side step removal
Bonet Guard
Silicone vac pipes
cheers for that , think i'll give it a go :wink:
glynn969
Vehicle Name: Red Monster
headlight protectors
steinmetz grille
pipercross induction kit
safari snorkel
FOG stickers
braided brake hoses
Skype Username: glynn969
I have just downloaded the free mm tracker for the android but how do i load maps on it. :confused:
Re: Memory Map for Android - Beta version FOC by BadBoy on Mon Dec 19, 2011 8:17 pm
Skype Username: paul.bush21
No good for those of us who have a Blackberry. :?
Re: Memory Map for Android - Beta version FOC by stevd on Mon Dec 19, 2011 10:24 pm
my maps worked perfect on the app, i don't think i did anything special. its worth a try.
stevd
pro Comp Shocks
Side step removal
Bonet Guard
Silicone vac pipes
Re: Memory Map for Android - Beta version FOC by yaki on Mon Dec 19, 2011 10:30 pm
Re: Memory Map for Android - Beta version FOC by stevd on Tue Dec 20, 2011 12:21 am
I didn't have to do any of that they just worked and i kno w mine aren't the newer versions. i must just be lucky
stevd
pro Comp Shocks
Side step removal
Bonet Guard
Silicone vac pipes
Re: Memory Map for Android - Beta version FOC by yaki on Tue Dec 20, 2011 12:28 am
No tested myself, have been lurking on the MM forums and a few peeps had posted they couldn't read older maps and the MM support guy mentioned the £20- fee to unlock for older non DRM maps
Using MMTracker at the mo, no problems apart from it doesn't seem to play with rxf files from Wayfinder and some of my routes I had converted to GPX format failed to work but still early doors
