Frontera Technical Support • View topic - pc wont start
pc wont start
pc wont start by Drift on Sun Apr 10, 2011 10:29 am
I'm on my phone. The main pc will not start, it has the fans spinning but nothing else, would I be correct thinking its the power suppy unit at fault? No beeps or anything though now and again it will fire up. It's clean inside too. Thanks
Re: pc wont start by Rich on Sun Apr 10, 2011 10:33 am
take it back steve it dont sound to good
Re: pc wont start by Drift on Sun Apr 10, 2011 10:35 am
Its out of warranty
Re: pc wont start by Rich on Sun Apr 10, 2011 10:49 am
it dont seem like five minute since you bought it
it sounds like it could be the psu to me
Re: pc wont start by Drift on Sun Apr 10, 2011 10:52 am
Think they are cheap enough ?
Re: pc wont start by stretch on Sun Apr 10, 2011 11:06 am
probably psu which are cheap enough these days just make sure you get the right one ie modular or non modular. If it's a newish pc ie uses SATA drives it'll be a modular one you want. If your not sure post some pics and i'll tell you.
Re: pc wont start by gregster on Sun Apr 10, 2011 11:16 am
Too much sheep porn Ste.... :shock:
Aint the kidz got a pc you can try the psu out of to prove a point, and then borrow the PC in lieu of them being housed and fed until yours is fixed..
Re: pc wont start by James Bass on Sun Apr 10, 2011 11:28 am
I had a similar problem with mine a few yrs ago. Turned out it was the Motherboard. :shock:
Re: pc wont start by alsavs on Sun Apr 10, 2011 11:40 am
Do you get any activity from the leds on pc also do you get a message on monitor ie No Signal.
Alan.
alsavs
Registration Year: 1992/K
Modifications: Non as yet
Re: pc wont start by snapper on Sun Apr 10, 2011 11:54 am
Think.....
Fans spin, power?
At what point during the boot up process does it fail? Does it get to:
1. CMOS Check Screen.
2. WIndows 'failed to load' screen, giving you a choice to boot normally or start in safe mode
3. The normal WIndows Boot Screen.
Can you get into the Setup (press 'Delete' as you boot or F2, depends on the CMOS it's running). If you can get into that then I would say the Power Supply is okay.
Places to look, things to look for/consider.
Check all connections
Any stuck keys on the keyboard?
The kids.... spilt a drink on it? dunked the mouse in a drink? (dont larf, mine did once)
Swap the keyboard & mouse, try again (the current CMOS settings may have it stall the load process if either of these are faulty)
You say it's clean inside... Please tell me you havent stuck the hose from the hoover in there and had a wave about? Is the hose end metal or plastic?
Check all connections inside the box for tightness and correct location
have the kids 'posted' a note to granny/biscuit etc in the CD slot
Has the dog/cat bleep on it?
Does the SCREEN work? more than one PC has made it to the re-cycle because the screen died and they never sussed it :wink:
Good luck...
Re: pc wont start by BoxCleva on Sun Apr 10, 2011 1:43 pm
PSU is one possibility, but not the only one. as mentioned above do you have another PC you can swap the PSU out of and test ?
Re: pc wont start by Drift on Sun Apr 10, 2011 7:05 pm
Thanksguys, kids aint been near it, other pc is a laptop, lights come on but the hard drive is not booting , took side off checked connections and nothing at all at monitor, tested monitor on laptop. Only activity are the fans.
Re: pc wont start by Alchamist on Sun Apr 10, 2011 7:13 pm
Fans + no beeps + no activity = dead motherboard most likely I'm afraid Ste.
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: pc wont start by Drift on Sun Apr 10, 2011 7:26 pm
If it was the mother board how much am I looking at , the pc is an ixtreme x6622uk ? And would my operating system still work on a new board? Win7
Re: pc wont start by James Bass on Sun Apr 10, 2011 7:28 pm
When mine went Ste, I had to wipe everything and start from scratch. :cry:
Re: pc wont start by BoxCleva on Sun Apr 10, 2011 8:01 pm
Re: pc wont start by Drift on Sun Apr 10, 2011 8:38 pm
Well Im on it now, it fired up no problem this time :? well just a bit slow booting up but nothing drastic, are there any diagnostics I can run while its operating now?
Also whats the cost of upgrading :oops:
Re: pc wont start by Alchamist on Sun Apr 10, 2011 8:39 pm
How long you had it Ste? If you're just surfing and office-ing, then I might be able to sort you out a machine. It won't be top spec or gaming capable, but it will do what you need :)
Jay
Alchamist
Modifications: .
* CB
Re: pc wont start by Drift on Sun Apr 10, 2011 9:10 pm
Cheers Jay, its been just over a year since I got it, Keiron does some gaming on this but nothing too intensive as it only a
Graphics
Monitor
Name TS902W on NVIDIA GeForce GT 320
Current Resolution 1440x900 pixels
Work Resolution 1440x900 pixels
State enabled, primary
Monitor Width 1440
Monitor Height 900
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Memory 1024 MB
Memory type 2
Driver version 8.17.12.6658
CPU
Intel Core 2 Quad Q8300
Cores 4
Threads 4
Name Intel Core 2 Quad Q8300
Code Name Yorkfield
Package Socket 775 LGA
Technology 45nm
Specification Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
Family 6
Extended Family 6
Model 7
Extended Model 17
Stepping A
Revision R0
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, Intel 64
Virtualization Supported, Enabled
Hyperthreading Not supported
Fan Speed 1081 RPM
Bus Speed 332.5 MHz
Rated Bus Speed 1329.9 MHz
Stock Core Speed 2500 MHz
Stock Bus Speed 333 MHz
Average Temperature 38 °C
Caches
L1 Data Cache Size 4 x 32 KBytes
L1 Instructions Cache Size 4 x 32 KBytes
L2 Unified Cache Size 2 x 2048 KBytes
Core 0
Core 1
Core 2
Core 3
RAM
Memory slots
Total memory slots 2
Used memory slots 2
Free memory slots 0
Memory
Type DDR3
Size 4096 MBytes
Channels # Dual
DRAM Frequency 532.0 MHz
CAS# Latency (CL) 7 clocks
RAS# to CAS# Delay (tRCD) 7 clocks
RAS# Precharge (tRP) 7 clocks
Cycle Time (tRAS) 20 clocks
Command Rate (CR) 1T
Physical Memory
Memory Usage 47 %
Total Physical 3.99 GB
Available Physical 2.13 GB
Total Virtual 7.99 TB
Available Virtual 7.99 TB
SPD
Number Of SPD Modules 2
Slot #1
Slot #2
Hard Drives
WDC WD10EADS-22M2B0 ATA Device
Manufacturer Western Digital
Heads 16
Cylinders 16383
SATA type SATA-II 3.0Gb/s
Device type Fixed
ATA Standard ATA8-ACS
48-bit LBA Supported
Serial Number WD-WCAV58882747
Interface SATA
Capacity 977GB
Real size 1,000,204,886,016 bytes
S.M.A.R.T
01 Read Error Rate 200 (200 worst) Data 00000000EB
03 Spin-Up Time 115 (107) Data 0000001C52
04 Start/Stop Count 100 (100) Data 00000002EA
05 Reallocated Sectors Count 200 (200) Data 0000000000
07 Seek Error Rate 200 (200) Data 0000000000
09 Power-On Hours (POH) 096 (096) Data 0000000DE0
0A Spin Retry Count 100 (100) Data 0000000000
0B Recalibration Retries 100 (100) Data 0000000000
0C Device Power Cycle Count 100 (100) Data 00000002E8
C0 Power-off Retract Count 200 (200) Data 0000000094
C1 Load/Unload Cycle Count 172 (172) Data 0000014CE6
C2 Temperature 109 (102) Data 0000000026
C4 Reallocation Event Count 200 (200) Data 0000000000
C5 Current Pending Sector Count 200 (200) Data 0000000001
C6 Uncorrectable Sector Count 200 (200) Data 0000000001
C7 UltraDMA CRC Error Count 200 (200) Data 0000000000
C8 Write Error Rate / Multi-Zone Error Rate 200 (200) Data 0000000001
Temperature 38 °C
Temperature Range ok (less than 50 °C)
Status Good
Partition 0
Partition ID Disk #0, Partition #0
Size 12.0 GB
Partition 1
Partition ID Disk #0, Partition #1
Size 100 MB
Partition 2
Partition ID Disk #0, Partition #2
Disk Letter C:
File System NTFS
Volume Serial Number FA630682
Size 459GB
Used Space 125GB (28%)
Free Space 334GB (72%)
Partition 3
Partition ID Disk #0, Partition #3
Disk Letter D:
File System NTFS
Volume Serial Number 32649D87
Size 460GB
Used Space 117MB (1%)
Free Space 460GB (99%)
Re: pc wont start by snapper on Sun Apr 10, 2011 9:27 pm
Where did you get it from mate? And did you get the extended warrenty thing with it?
