Problems with DELL laptop...
Problems with DELL laptop... by gregster on Sun Feb 27, 2011 2:47 am
Am having grief with one of our pc's...
Its a dell laptop running xp pro and it connects to the web normally via google chrome and a wireless connection...
The web access is playing up on it, the router seems fine, this pc works cool on it as does my works laptop via wireless...
If I disable the wireless on the laptop and then reactivate it it will find one maybe 2 web pages before coming up with
error 105 (net name not resolved)
Refresh it and it comes up the same again...
but if I disable the wireless connection and then reactive it and refresh it will normally find the page and maybe the next one before hanging up again...
Have checked everything that I know of (not much admittedly)....
Can anyone help before I put a hammer through it...???
Re: Problems with DELL laptop... by actung on Sun Feb 27, 2011 4:08 am
have u tried to check your firewall? it could be blocking you getting on
try disabling it then try get online with that chrome crap :p
or use firefox :wink:
it could also be dns related so i dunno if this will work but ive used this before when fixing certain issues with peoples pcs
http://support.microsoft.com/fixit/
i would try get a registry cleaner and run that 2
hope this helps :)
actung
Vehicle Name: THE JEEP
Modifications: 17"x8" mb atlanta alloys(think there america) and 255/65 hankook tyres
Region: Northern Ireland
Re: Problems with DELL laptop... by Smithy501 on Sun Feb 27, 2011 9:32 am
i agree google chrome is somewhat crap ,, i use Opera web browser because personally i like it better than fire fox and agen i agree registry cleaner will help or download ccleaner which will get rid of your junk and there is all so a registry clean option for missing MUI information or corrupted keys
If life hands you a lemon,,,,, Quickly grab it and throw it at someone!!
Smithy501
Location: Broome Shropshire Between Aston on clun and Craven arms
Re: Problems with DELL laptop... by BadBoy on Sun Feb 27, 2011 9:58 am
Could be a pain to do, but it will eliminate one problem. Can you plug it into your router with an ethernet cable and switch off the wireless.
Give that a try. If everything works then your problem lies with the wireless connection only, not the net connection or browser, or any other settings.
Skype Username: paul.bush21
Re: Problems with DELL laptop... by Wilberforce on Sun Feb 27, 2011 10:08 am
I'm impressed... Nobody's asked "have you changed anything" yet, heh. Seriously though, have you perhaps used Microsoft Update to install any patches onto Windows?
I don't use Chrome on my systems, am a Firefox man, but I'm more inclined to think that the problem lies with a setting somewhere in the properties of the wireless connection. Try this to see if it helps - I'll admit k pinched it from elsewhere, but that's cos I'm on my iPhone, heh.
Okay, on the computer with the problems:
Click Start
Click Control Panel
Click Network Connections
Right-click on Wireless Network Connection
Click Properties
Click the General Tab
Click Internet Protocol or Internet Protocol v4 in the "This connection uses the following items" box (keep the checkbox checked).
Click the Properties button.
Click the circle next to "Obtain an IP address automatically"
Click the circle next to "Obtain DNS server address automatically"
Click Ok
Click OK
Restart the computer and see if this fixed the problem.
Worth a try, cos it might just do the trick, and won't break anything else if not.
Jim
Re: Problems with DELL laptop... by Wilberforce on Sun Feb 27, 2011 10:09 am
Also, what BadBoy said is spot on - if you can plug it in and connect with a cable, it's definitely the wireless
Connection settings
Re: Problems with DELL laptop... by gregster on Sun Feb 27, 2011 11:11 am
Its not working with ethernet cable, tried that before posting, but couldnt get it to work with ethernet cable months ago when I had a wireless frequency clash with the cctv...(have tried it with cctv off as well)..
Will try the other stuff and then select a suitable size hammer if it doesnt work... :twisted:
EDIT>>>> All working again now...dunno what it was but ran pirisoft c-cleaner and seems to be ok now...
Re: Problems with DELL laptop... by Smithy501 on Sun Feb 27, 2011 2:04 pm
ccleaner is awesome tool i install it on every pc i build and repair and attach a note to keep updating it reguraly
Smithy501
Re: Problems with DELL laptop... by actung on Mon Feb 28, 2011 4:24 am
i could giv u perfect optimizer 5.0 with working serial :)
or uniblue powersuite but with uniblue u have to go in and manually edit your registry to install the crack to get it working fully
as many have said already ^^ up there... it could be a number of things u have to do to fix this
its all about trial n error without a hammer lol
does the ethernet (RJ45) cable even connect when u plug it in? if not it could either be incorrect drivers or a faulty network card
regarding resetting the tcp/ip - there is a netstat command u run from dos but i cant remember the full command to reset it but im sure u could google it.
also i think dell systems prefer to let them manage wireless connections rather than micro$oft
dont forget you can always reformat it and start from scratch if stuck :)
OOPS - only read u got it fixed :)
actung
