oops didnt realize that,ye it is extreme but if all else fails then its an option,but not for this lappy,i do think its a driver problem though rather than hardware,vista is the new windows me ie major fail hence windows 7
another thing you can try is disabling the uac,when vista first came out lots of people had problems with games and programs not saving profiles,you would set a game up with all your keys and video settings but it wouldnt save,next time you boot up it was all set to default again,disabeling uac cured this,its been a long time since i ran vista but if i remember right click start button and type msconfig,then click the msconfig link,click tools and scroll down to disable uac(may say uap),disable it then save and reboot pc,then istall your chipset and vga drivers again and see it if that cures it,if it doesnt you can allways turn uac back on if you wish,they say its a security risk to have it turned off but ive never used it as it causes to many problems,i dont even have it turned on in windows 7. also when installing the drivers if it has its own setup.exe dont just double click it,right click it then run as administrator.
