Frontera Technical Support • View topic - FTP with Windows 7
FTP with Windows 7
FTP with Windows 7 by Trugga on Fri Sep 10, 2010 8:23 pm
Help :?
I have Windows 7 Home Premium, with with McAfee AV
In the past, on Windows XP, I've used Cute FTP to ftp files to my personal webspace, but I can't get it to work on this new PC.
Yes, I have disabled the Windows firewall
Yes, I have disable the McAfee firewall (albeit temorarily in anticipation of ftping)
Yes, I have added CuteFTP to the 2allow" list in McAfee
but each time I attempt to connect, ite reports the password is incorrect (it can't be as I've checked with the domain paperwork - and I'm sure it worked before I instaled McAfee)
Any suggestions (other than removing McAfee) ?
Re: FTP with Windows 7 by furball on Fri Sep 10, 2010 8:57 pm
I'm assuming you're using the latest version? I believe 8.3.3 has been tested and verified as compatible.
That said, I prefer http://www.ftpcommander.com/ myself, mainly cos they use dangermouse for the desktop icon :D
furball
Re: FTP with Windows 7 by Trugga on Fri Sep 10, 2010 10:03 pm
Thanks for that...
I download, installed and the sample sites appear to work. Get a similar message though when trying to access my own site (although it dissapears off the screen pretty quick)
I think I might need to contact my host... unless anyone else has any other ideas.
Re: FTP with Windows 7 by Frenchfarmer on Fri Sep 10, 2010 10:09 pm
Double Dutch to me but I know how you feel. :)
Best of luck.
Frenchfarmer
It works!!!!
Re: FTP with Windows 7 by furball on Fri Sep 10, 2010 11:19 pm
Defo sounds like the problem is with the site hosting service guv. If other sites are working OK then it's unlikely to be the software
furball
Re: FTP with Windows 7 by Alchamist on Sat Sep 11, 2010 7:16 am
Got a shell account anywhere? If so, you could easily confirm if it were a local issue or not
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: FTP with Windows 7 by Trugga on Mon Sep 13, 2010 6:36 pm
Problem solved :D
Bloomin passwords :oops:
Re: FTP with Windows 7 by Frenchfarmer on Fri Sep 17, 2010 9:01 pm
Frenchfarmer
It works!!!!
