Frontera Technical Support • View topic - what button
what button
what button by fogman on Mon Aug 16, 2010 9:50 pm
is there a button on the keyboard that can change the letters to other symbols or numbers ?
my lappy goes into hibernation after a few minutes if not used and so requires me to enter my password to start up again which normally isnt a problem but occasionally 1 of my cats will settle down and go to sleep on it when ive left the room to make a cuppa etc, so when i return and reclaim my pc i enter my password but im told its not recognised, i try several times but i always have to turn it off and do a full restart ! other times he will hop on it while ive gone to get something from another room so it dosent have time to go into hibernation before i return & it that case when i try to access a site i can enter my password but some numbers will be entered in the box instead of the intended letters although i have obviously selected the correct letters !
Re: what button by Rifleman on Mon Aug 16, 2010 9:53 pm
The cat has maybe sat on the "numbers lock" button.
Re: what button by Road Hog on Mon Aug 16, 2010 9:54 pm
Has it turned CAPS LOCK on ? passwords are case sensetive :wink:
Re: what button by Norse on Mon Aug 16, 2010 9:57 pm
Num Lock Button
Caps Lock
FN button sometimes but most likely the first two
IT support/Advice just ask me
Norse
+2" Sus Lift
+2" Body Lift
DIY Snorkle
Shedload of stickers
To do
Boot Organiser construction
Remove spare wheel holder
Perhaps a CB
Re: what button by fogman on Mon Aug 16, 2010 10:20 pm
its definetly not the capps
whats the number locks button then ??
Re: what button by Rifleman on Mon Aug 16, 2010 10:25 pm
Top row, 4th from the right mate.
Press it then try and type, see what happens.
It should make you type just numbers until pressed again. Is this whats happening?
Re: what button by fogman on Mon Aug 16, 2010 10:31 pm
top row 4 th from right is the prtsc sysrq button and that didnt make any difference
Re: what button by Road Hog on Mon Aug 16, 2010 10:41 pm
it does vary on lappies from maker to maker,have you got a button ..... Num Lk ? it may be dual function & require shift of Fn button pushing at the same time
Re: what button by james'll fix it on Tue Aug 17, 2010 8:16 am
Turn off the hibernation, or extend the time. I would expect it to be a setting in control panel/power settings. What OS you using?
Or close the lid if your leaving it.
james'll fix it
Modifications: +2"
repaired seat base
Re: what button by fogman on Tue Aug 17, 2010 11:36 am
right ive found the num lock button & its not that , im using xp & im quite happy with the settings how they are james & quite often ne nips on as soon as i go out foir a bag of crisps or similiar, the ideal answer would be to sell the cats :D but theyre my babies :wink: its really a case of i need to find out just so it hasnt BEATEN ME :roll:
Re: what button by stretch on Sat Sep 25, 2010 9:00 am
Sometimes the scroll lock button can cause this problem
Re: what button by DeathRace on Wed Oct 13, 2010 9:51 am
better consult your technician than experimenting something.
it is not applicable to try any thing with any knowledge on it.
DeathRace
Re: what button by andysd1 on Wed Oct 13, 2010 12:38 pm
electrify the key board, lol,(only joking)
try putting it in to sleep mode until you get back to it
Re: what button by fogman on Wed Oct 13, 2010 3:40 pm
Re: what button by gregster on Wed Oct 13, 2010 3:51 pm
Re: what button by fogman on Wed Oct 13, 2010 8:20 pm
Re: what button by gregster on Wed Oct 13, 2010 8:28 pm
