Frontera Technical Support • View topic - Grrrrrrr new laptop fooked up
Grrrrrrr new laptop fooked up by Rich on Tue May 11, 2010 6:45 pm
The kids brand new laptop arrived to day through Home access i unpacked it and booted it up all seemed ok with it. I shut it down and put it away until they came home from school
my daughter booted it up and set about running one of the education packages on it which caused the blue screen of death :shock: :shock: (it booted back up ok)
she did what she wanted to do on it and the shut it back down and now the bloody thing will not boot up just a black screen :shock: :shock: the power light is on
the hard drive light flashes for a few seconds then stops so it looks like it will be going back tomorrow
Its a samsung R519
Re: Grrrrrrr by huggy on Tue May 11, 2010 8:52 pm
a friend of mine got the same pc,would not go online full stop and the software that its stuffed with was buggy,i uninstalled all the pre installed junk on it and it now runs fine,i would suggest running the restore option that restores it from the partition, or if you got a recovery disc with it use that,once you get it into windows uninstall all the education stuff and so called online security features.
huggy
Re: Grrrrrrr by Rich on Tue May 11, 2010 10:18 pm
i would if it even booted up lol
Re: Grrrrrrr by huggy on Wed May 12, 2010 8:21 am
turn it on and insert the recovery cd then turn it back off,then turn it and keep pressing f10,you should get a boot option,tell it to boot from cdrom/dvdrom,if it doesnt boot then maybe it is a hardware problem,if so send it back :wink:
huggy
Re: Grrrrrrr by domino on Wed May 12, 2010 8:54 am
Remove the battery for a few minutes then try again :)
domino
Sleeper
Model: 2.5 TDS Transglobe 5dr
Re: Grrrrrrr by Rich on Wed May 12, 2010 12:08 pm
i phoned there IT support line this morning at 9.30 they said we will ring you back in a mo but still no call back :evil: :evil: :evil:
Re: Grrrrrrr by Roo on Wed May 12, 2010 12:23 pm
Re: Grrrrrrr by domino on Wed May 12, 2010 1:31 pm
Did you try taking the battery out for a while?
domino
Sleeper
Re: Grrrrrrr by Rich on Wed May 12, 2010 2:06 pm
Re: Grrrrrrr new laptop messed up by adyclemo on Tue May 18, 2010 10:49 am
Them asking you to start taking the machine apart is well beyond the boundries of what they should be doing. I work in the technical centre of a well known pc retailer and that is something even we would not do. Beyond the basics of unplugging from the mains taking the battery out and holding the power button down for 30sec and thn plugging back into the mains, if this fails to the machine to post and display anything on the screen then we would be asking for to bring it back for an exchange or repair. It sounds like the mainboard has failed in someway. I suspect the BSOD error could have been a memory crash dump or a driver irql error are the most common. In the event of a memory crash dump people wrongly assume its down to memory issues, this is not always the case.
No dislpay (post) can be down to a component not seated correctly to a failed component in your case mainboard. Although i appreciate why they asked you to remove the memory its something they shouldnt have done and i wouldnt have done, it leaves yourself in the position of blame if they prove it has been opened.
Just information if any didnt know look below.
If the machine failes during the first month its reasonable for a replacement to be requested. If the same fault occurs more than twice within the manufacturers warrenty on the same equipment then it is right to assume there is a inherrent manufacturing fault for that issue and the manufacturer can be held responsible for this fault for upto 3 years althought the consumer has to prove they have given reasonable time for the fault to be rectified and have taken care of the product and the failure is not down to how the product has been used. Several faults not related to each other are treated as individual cases and do not come under this.
This warrenty is carried through the reseller you purchased the equipment from through the legal dpartments not at store level. Dont go to the store and demand it to be sorted as they will just clear you off, be polite and understand that it is not dealt with at store level and the store will not take the equipment off you because if they do the store will be accepting liabilty for the fault. The legal departments will arrange for the equipment to be uplifted and assessd and any manufacturing defacts will be rectified, anything that has been caused by improper use etc will not.
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Re: Grrrrrrr new laptop messed up by Rich on Fri May 21, 2010 11:12 am
ive heard back from them the laptop is dead so a new one will be here on monday
Re: Grrrrrrr new laptop messed up by Roo on Fri May 21, 2010 12:49 pm
Re: Grrrrrrr new laptop messed up by Rich on Mon May 24, 2010 9:53 pm
Fookin he'll the new laptop arrived today and it surposed to have 2gig of ram but it's only showing one so it's back on the phone tomoz
