Problems with FF
Problems with FF by headbanging on Wed Apr 14, 2010 9:40 am
Can anyone help with an issue i'm having with FF.
After running a clean up yesterday, FF isn't loading the full page, and many background images aren't loading. Also, any threads where I have put links in for images, don't work, but if the image is uploaded as an attachment, it does. I have checked my picture loading permissions and those are all OK.
My work software uses Java, and thats not loading right, and i'm not getting any Java errors coming up. if anyone knows C Panel, in File Manager, the main 'frame' loads, but no file structure or folders appear.
But everything still works in IE, so i'm having to slum it at the moment and use IE.
Does anyone know how I can repair the issue?
Piccies of how FOG looks for me:
PS i've had to post this in IE as it wouldn't post in FF
headbanging
wound up torsion bars (2")
flipped top ball joints,
roof light pod
blue-tooth CD player
modified side repeaters
smoked tail lights
uprated turbo hoses
Skype Username: BadgesPatches
Re: Problems with FF by Sir-Doris on Wed Apr 14, 2010 11:04 am
Screen looks the same as mine (FF 3.6.3)
Have you tried updating Java or Firefox since? Possibility that it was using older cached images from before the forum maintenance a while back?
