Ok, here's a good one for the teccy types.
Yesterday I had a call-out to a shop where one of the tills wasn't connecting to the network (XP PC based system). I tested all the cables and found no faults, I was getting a good link to the switch at the till end and yet the till wouldn't connect.
I figured it must be the till, but my tester could see and talk to it's NIC so that looked OK too.
Next I started experimenting with the till next to it, using a 20m patch lead to see what happened when I plugged till 1 into till 2's data point etc. I eventually concluded that it must be the patch lead that was causing the problem, even though it tested OK, so to prove it I connected the problem till to it's own data point with the 20m patch lead and it worked fine.
Concluding that I had resolved the problem I went and got a brand new patch lead out of the van and.... nothing, no connection. I thought maybe I had a dodgy lead so I took the one off the neighbouring till (a 'known good working' lead) and still nothing. So I plugged the 20m lead back in and it connected immediately.
So the question is this, why would a 20m lead work when a 2m one won't? The only potential clue I have is that some of the wiring for the security tagging system runs up the same pole into the ceiling as the cable for the data point for this till, and every time I plugged/unplugged a patch lead it set the tagging alarm off (which is odd, I assume there is also a problem with the tagging system, but I don't know anything about it so I didn't start messing with it).
