Frontera Technical Support • View topic - Disk De-Fragmenter.
Disk De-Fragmenter.
Disk De-Fragmenter. by FUDDY MUCKER on Thu Dec 17, 2009 11:50 am
Right techy boffins !!!! Just a quicky for you.
I've just started my fortnightly computer clean up, getting rid of spy ware, anti virus, unused files etc.
I've used the "Performace and Maintainence" Screen to run Disk Clean up, no problems.
Then I come to use "Disk DeFragmenter" and strange things happen.
I open it up and try to analyse the C: disk and get this message ..........
"Disk Defragmenter Has detected that Chkdsk is sheduled to run on the volume (C:). Please Run Chkdsk/f."
And wont defragment my hard drive.
I've typed Chkdsk/f into the "Run" program an nothing happens. Type it again, missing off the F and it checks the disc in "Read Only" mode.
Im currently running, Kaspersky Internet Security, all fully updated and running correctly, and Adware SE spyware, again all updated and running currectly.
I've checked the "Sheduled Tasks" in the Performance and Mantainance section, nothing is showing up.
My internet browser is Mozilla, again fully update. operating system is Windows XP Service Pack 3, fully updated.
Just to give an idea, the past few days the computer has been running very slow, with the pages freezing or slowly scrolling down from the top to the bottom, hence why I decided to clean the computer up.
Any idea's would be helpful. I'm not computer illiterate and know my way around, but this one I can't understand.
Cheers folk.
Re: Disk Fragmenter. by BadBoy on Thu Dec 17, 2009 12:16 pm
Step 1 Run Windows XP normally, allowing it to load fully.
Step 2 Access the "My Computer" menu. You can do this by clicking the Start menu and clicking the "My Computer" menu option. You can also double-click the "My Computer" icon if you've enabled it on your desktop.
Step 3 Right-click on the drive on which you wish to run the Chkdsk F command.
Step 4 Click "Properties" in the right-click context menu.
Step 5 Click on the "Tools" tab in the Properties window.
Step 6 Click on the "Check Now" button in the "Error-checking" frame of the Tools tab.
Step 7 Click in the "Automatically fix file system errors" check box under the "Check disk options" frame in the following window. This is the step which enables the "/f" command in Chkdsk.
Step 8 Click "Start" to begin the Chkdsk scan. If there are a lot of processes running in the background, or if Chkdsk determines that it should be run when you next restart your computer, it will suggest it. It is always advisable to run the Chkdsk from the restart in this case.
Step 9 Set your system to safe mode with the "/SAFEBOOT" command from the MSCONFIG program. Click "Start" and "Run." Type "MSCONFIG" and enable the "/SAFEBOOT" option from the BOOT.INI tab if your anti-virus or anti-spyware software is conflicting with the Chkdsk process.
Let me know how you get on.
Failing that have a look at this video http://www.ehow.com/video_4872358_run-c ... ws-xp.html
Actually. Watch the video first. Should sort it for you
Skype Username: paul.bush21
Re: Disk De-Fragmenter. by Drift on Thu Dec 17, 2009 1:38 pm
I use defragler from CC much better than the windows version
Re: Disk De-Fragmenter. by Sir-Doris on Thu Dec 17, 2009 3:13 pm
Perfect Disk or Diskeeper depending on PC's intended use.
Diskeeper is very much fit and forget. Automatically defrags drives in the background, uses minimal resources. Use this on the laptop.
Perfect disk has similar fit and forget background defragging but is a bit more disk intensive as it aims to get as large a block of free space as possible. Again uses very few resources.
Re: Disk De-Fragmenter. by domino on Thu Dec 17, 2009 4:28 pm
Also worth mentioning - if your hard drive(s) are running on NTFS a defragmenting brings little difference to the operation or 'speed' of the PC as NTFS 'sorts' data (bits) by default.
domino
Sleeper
Model: 2.5 TDS Transglobe 5dr
Re: Disk De-Fragmenter. by jcv1968 on Thu Dec 17, 2009 5:31 pm
1) Abuse tower verbally.
2) Attempt to defrag.
3) Strike tower with fists whilst verbally abusing.
4)Attempt to defrag.
5) Open window.
6) Throw tower from window.
My other Frontera is a Frontera. My Corsa is a baby Frontera.
jcv1968
Vehicle Name: Freddy
Modifications: Refitted a propper vauxhall radio!
Rebuilt engine, fast road cams, new injectors, Lamda sensor, Crank sensor.
Re: Disk De-Fragmenter. by Alchamist on Thu Dec 17, 2009 8:13 pm
Easy fix ... format the drive and put a real operating system on! ;)
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: Disk De-Fragmenter. by Wilberforce on Thu Dec 17, 2009 8:43 pm
Re: Disk De-Fragmenter. by Alchamist on Thu Dec 17, 2009 8:48 pm
God no! Haven't you kept up with any of my threads in here! :lol:
I'll give you a hint ...
Jay
Alchamist
Modifications: .
* CB
Re: Disk De-Fragmenter. by Trotter on Thu Dec 17, 2009 10:13 pm
Hey Fudster!
Try using System Mechanic 9 from iolo.com
It does the lot including the registry! ( without screwing it up! )
Half of the problems with slow computers are down to cr*p in the registry anyway!
Clear out the rubbish from the registry and you should see a distinct improvement!
Failing that, try MagicDefrag from Ashampoo! You can get this for FREE!
Noli Illegitimi Carborundum
Trotter
Registration Year: 1992/K
Vehicle Name: The Burgundy Bus
Skype Username: rodney.craik
