Looks like I'm in trouble with the Mrs's again... She asked me what I'd most like to do to her body... Apparently "Identify it" is not the correct answer!
Modifications: Drive a 2.2dti olympus, 2.8 lwb and 2.0i sport. Breaking... 2.4i and 2.3td 2.0i C20ne and x20se x 4 2.8tdi x2 2.2i A 2.2i B LWB x3 x22dth B dti lwb x3 y22dth B dti lwb x5 Call Fronty4x4spares on 01622 739908. Same day dispatch, next day delivery on 95% of items.
Modifications: extended rear shackles (3") wound up torsion bars (2") flipped top ball joints, viscous fan removed, and replaced with an electric fan,(switch in cab) roof light pod cut down nudge bar with two long range fogs blue-tooth CD player she is wearing a set of sport wings and a B- series bumper modified side repeaters smoked tail lights removed spare wheel holder (swing arm) uprated turbo hoses
