Any PHP Scripting experts out there?
Any PHP Scripting experts out there? by headbanging on Fri Oct 30, 2009 12:11 pm
This may be a bit of a long shot, but I know the power of FOG, and thought I would give it a try, as no where else has been able to help so far.
I have a few websites that run on open source php scripting. I have a problem with one them, and cannot see where the problem is, or what is going wrong.
To begin, all the links are in place, and everything works, until I click one link, and then I get a blank page. Totally white, with nothing there (not even white text). I then clcik to view the page source, and this is also blank. Nothing on the list at all, not even a <?php
The URL is displayed as www.mysite/catalog/correctfile.php and when I type the URL in the address bar, it works.
I have tried uploading clean copies of the files, but that didn't help.
I have tried copying files from a known working site, but that didn't help, and the problem persists.
I have posted this on other sites, but no one seems to be able to help. So do any FOG experts know where I can begin to look to find out what the error is thats causing the blank page?
PS the programme is OSCommerce and the problem is with the Checkout, namely checkout_process.php
headbanging
wound up torsion bars (2")
flipped top ball joints,
roof light pod
blue-tooth CD player
modified side repeaters
smoked tail lights
uprated turbo hoses
Skype Username: BadgesPatches
Re: Any PHP Scripting experts out there? by domino on Fri Oct 30, 2009 12:41 pm
If you want to PM me the details I'll check it out for you :)
Do you have access to the server it's running on? tailing the log files usually tells you exactly what the problem is.
Should probably mention I was a PHP developer moons ago and i'm currently a sys admin/tech analyst for a webhosting company aannnddd I run OSC on my own site :)
domino
Sleeper
Model: 2.5 TDS Transglobe 5dr
Re: Any PHP Scripting experts out there? by headbanging on Fri Oct 30, 2009 1:01 pm
Hi Domino,
Thanks for that.
I have checked the Error logs using C Panel, and it's not showing as an error in there. Which is what is throwing me out.
I will send a PM with some more details.
Thanks
headbanging
roof light pod
smoked tail lights
uprated turbo hoses
Re: Any PHP Scripting experts out there? by domino on Fri Oct 30, 2009 2:00 pm
Replied.. and working on it :)
domino
Sleeper
Re: Any PHP Scripting experts out there? by headbanging on Fri Oct 30, 2009 7:41 pm
Just thought I would reply to this, as we now have the problem solved.
Domino didn't tell me the exact problem, but was just able to say a few words, that triggered a few ideas to get the problem sorted, and for that I am very gratful. After 2 days of hair pulling, we were there within an hour.
There are times when you stare so long at a problem that you can't find the solution.
And the last place I expected to find a solution was FOG (after the 'official' forums failed abissmally), Well done FOG! and thanks again to Domino :D
headbanging
roof light pod
smoked tail lights
uprated turbo hoses
Re: Any PHP Scripting experts out there? by domino on Fri Oct 30, 2009 8:53 pm
Glad to have helped.
I often find myself in similar situations - you work on something or stare at it for an age and you get nowhere. A fresh pair of eyes can pinpoint it straight away or, like you say, alter your thinking slightly. I've been very embarrassed by stuff like that before :oops:
domino
Sleeper
Re: Any PHP Scripting experts out there? by Drift on Fri Oct 30, 2009 9:13 pm
Well done guys 8)
