Safemode
Safemode by Rich on Fri Oct 16, 2009 11:58 am
well ive messed my laptop up :oops: i downloaded zone alarm (firewall) program yesterday and it froze half way through the install
well now i can only boot my laptop up in safemode. If i try to boot it up normally it gets so far and just stops,and then i get the blue screen of death saying starting phyical memory dump :shock:
ive tryed doing the system restall thing but thats not working it just says no restore points :oops:
As anyone got an idea of what else i can try before i reinstall vista
Re: Safemode by BadBoy on Fri Oct 16, 2009 1:03 pm
Have you tried booting in safe mode, then completing the install.
It has probably made changes to your registrey but as it has not completed the install the registrey is incomplete.
Completing the install should correct the registrey.
If that works then back up the registry and then run a registry cleaner to remove any corrupt files left by the failed install.
Skype Username: paul.bush21
Re: Safemode by Rich on Fri Oct 16, 2009 1:27 pm
i can even find any reference to zone alarm anywhere
Re: Safemode by Sir-Doris on Fri Oct 16, 2009 1:48 pm
Boot in safe mode and uninstall zone alarm if poss, failing that edit the registry and remove any references to zone alarm including any folders etc. there may be a seperate program for removing all traces of zone alarn on their website, I know adobe and a few other companies have small programs specifically for removing all traces of their software.
Could always check the zone alarm forum for help: http://forums.zonealarm.com/
Re: Safemode by Rich on Fri Oct 16, 2009 4:24 pm
ok iam getting some were ive managed to boot in normal mode
i have disabled all of the services and am in the process of starting each one individuality to see if i can find the ones stopping me from booting up
Re: Safemode by Trotter on Fri Oct 16, 2009 8:30 pm
When you get it up and running, get a copy of "System Mechanic 9!"
This will clear out any rubbish from your hard drive AND Registry!
It is also usable on "up to 3 PC's"
This new version also clears things up for you by running in the background, but only when resources are not required elsewhere!
i.e. it doesn't interupt what you are doing.
It's available from "iolo.com" and costs $24.95 (yes,that is dollars.)
Good Luck!
Noli Illegitimi Carborundum
Trotter
Registration Year: 1992/K
Vehicle Name: The Burgundy Bus
Skype Username: rodney.craik
Re: Safemode by Rich on Sun Oct 18, 2009 7:33 pm
all back up and running now :D :D :D :D :D
