Printer problem
Printer problem by Krusher on Sat Sep 12, 2009 6:11 pm
I have a lexmark X1100 all in one printer that is not working. What has happened is when the cover was up during a cartridge change the cartridge carrier was moved. Now when you turn th printer on the cartridge carrier thing flies back and forth hitting both sides of the printer chassis.I have tried resetting it, reinstalling it and the driver but no luck. Has this happened to anybody and if you fixed it, what did you do?? :? :?
Re: Printer problem by simmyoto on Sat Sep 12, 2009 8:41 pm
There is a thin plastic strip at the back of the cartridge carrier called the encoder strip.
It should sit in a sensor on the back of the carrier (you wont be able to see it but you might just feel it)
sometimes the strip pops out of the sensor- so the printer doesnt know where the hell the cartridge carrier is causing it to either just not move or wack about like a rabid dog.
You can try to relocate the strip by "GENTLY" pulling it down, then forwards then up slightly- theoretically relocating it in the sensor.
You may just get lucky but its unlikely, it seems to be a common fault, Hopefully you got it free with your computer, and you didnt really pay good money for it!
if its still in warranty just take it back if the above doesnt work, if its not and the above dosent work, smash it intop tiny peices with a very large hammer and go and buy an epson! you may have seen the price of the lexmark cartridges- they give the printers away free because the cartridges cost more than the printer would in the first place! buy an epson and buy jet tec comp-atible cartridges (keep the free ones they give you sealed just in case you ever have to send it back you can put them in to make it look like you used them all along) the jet tec cartridges have been tested to be as close as you can get to the originals and the print quality is great!
simmyoto
Modifications: 31" saharah muds on wide offset alloys
Ash tray mounted cb
custom recovery points (black danglies)
Hella rallye 3000 sopts
Trooper hd coils
Polybushed
2" front windup
2" coil spacers (on order from mr weave)
Much much more to come
Re: Printer problem by Krusher on Sat Sep 12, 2009 8:56 pm
I did see a thin strip that the cartridge runs along, I will give that a try.
Thanks alot Simmyoto :wink: 8)
Re: Printer problem by Krusher on Sat Sep 12, 2009 9:58 pm
Well give that man a cigar!!
Cheers simmyoto, its up and running again. Oh yeah by the way I refil the cartridges so doesnt cost much anyway, about £12 for 6 refills.
Thanks again 8)
Re: Printer problem by Drift on Sat Sep 12, 2009 10:18 pm
Ive got a lexmark p4350 how do you refill the cartridges and can you refill colour too?
Re: Printer problem by Krusher on Sun Sep 13, 2009 12:35 am
You can buy a refil kit from tesco, colour and black. They come with instructions for all the major cartridges. Their not difficult to do once youve
done them a couple of times
Re: Printer problem by gregster on Sun Sep 13, 2009 12:40 am
Guess your printer runs out of PINK quickly Krusher......all them pickies you print off of your Fronty!!! :lol: :lol: :lol:
Re: Printer problem by Krusher on Sun Sep 13, 2009 12:42 am
:butt: :butt: :butt: :butt: :butt:
Re: Printer problem by simmyoto on Sun Sep 13, 2009 1:01 pm
well done krusher, you now have the pleasure of another year or so of fun with your lexmark! have you had the problem where the printer prints half a page then the carridge just stops yet? lol- sorry!
simmyoto
Ash tray mounted cb
Trooper hd coils
Polybushed
2" front windup
