internet speed test
internet speed test by Rich on Tue Jun 16, 2009 5:54 pm
my Internet has been a bit hit and miss lately so i did a speed test one using a sever in Manchester and one in maidenhead which one do i believe
Re: internet speed test by Alchamist on Tue Jun 16, 2009 6:01 pm
Both ... it depends on the route it takes and the lag it encounters. Here's mine
And just for fun
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: internet speed test by Rich on Tue Jun 16, 2009 6:02 pm
this ones a bit cr*p though
Re: internet speed test by Dupe on Tue Jun 16, 2009 6:05 pm
i use talk talk it all depends on what mood there inlol
Dupe
Re: internet speed test by Alchamist on Tue Jun 16, 2009 6:06 pm
Yeah, but see how the ping has increased. Also, it's after 6pm, when a lot of internet users get online after getting home from work .. plus most ISP's are capping speeds after 6pm to "protect their users" (translation: they don't want to invest in better infrastructure ;) )
Jay
Alchamist
Modifications: .
* CB
Re: internet speed test by Dupe on Tue Jun 16, 2009 6:08 pm
i know talk talk use aol so there clients get first place when it gets busy.
Dupe
Re: internet speed test by Alchamist on Tue Jun 16, 2009 6:09 pm
Erm ... lol
Jay
Alchamist
Modifications: .
* CB
Re: internet speed test by john (smifffy) on Tue Jun 16, 2009 6:10 pm
it all depens on your speed to start with & other useage
Re: internet speed test by Dupe on Tue Jun 16, 2009 6:17 pm
ok teches how do you get the speed test on the forum :?:
Dupe
Re: internet speed test by Rich on Tue Jun 16, 2009 6:18 pm
i think i will try again later
Re: internet speed test by john (smifffy) on Tue Jun 16, 2009 6:29 pm
go to http://www.speedtest.net/
do the test then under the map there is check your results box
on the right is the result of your tests under that is a link to it copy that and post here
it should look like this but i took a bit out show it will show as a text link
[url=http://www.speedtest.net][img]http://www.speedtest.net/rank/1376123498.png[/img[/url
Re: internet speed test by Drift on Tue Jun 16, 2009 7:02 pm
Virgin have a lot of over subscribed UBR's (the network areas) and that affects speeds, but they are migrating the 10meg and 20meg users will be ported over to the DOCSIS 3 network but will be running DOCSIS 2.
I think they will need a new ambit 256 modem to get the benefit.
Go to www.virginmedia.com/swapmodem and you can order an Ambit
The DOCSIS3 is primarily for 50meg users but they will use the DOCSIS 3 network as opposed to DOCSIS 2.
This theoretically should open up more bandwidth and increase end user speeds.
Re: internet speed test by Roo on Tue Jun 16, 2009 7:15 pm
My download speed is 5.63mp/s
Upload speed is 0.33mp/s
And it ping at 48ms
Sorry couldn't paste it or change it as it was set to Manchester :lol: :lol:
Re: internet speed test by Sir-Doris on Tue Jun 16, 2009 7:42 pm
Thats not bad roo, Im averaging between 4 and 5Mb/sec and you are closer to the local exchange as well.
Re: internet speed test by damrabbit on Tue Jun 16, 2009 7:44 pm
,32mm wheel spacers
1997 BMW 328i Touring(DEAD)
1993 gas guzzling monster ?
Re: internet speed test by Dupe on Tue Jun 16, 2009 8:12 pm
cheers smiffy but i think i will give it a miss at least some one is good enough to try an explain cheers mate :)
Dupe
Re: internet speed test by Ruathar on Tue Jun 16, 2009 11:05 pm
If I go through our network I get 10mb down and 2mb up, if I go direct through the modem I am getting 49mb down and 15mb up, but that is using the VM secret speed test site that they use for the engineers to test the speed of installations. If I use speed test I get the same through the network and only 42mb down direct. Speedtest.netwill loose you aout 5-10% due to loads at times.
'99 3.2V6 Auto Limited.
Ruathar
Re: internet speed test by dandan on Wed Jun 17, 2009 1:44 am
Our upload speed has always been really pants but at least download speeds are getting better :roll:
If you're sat there thinking things just can't get any worse, just wait......
dandan
Re: internet speed test by Dupe on Thu Jun 18, 2009 6:08 pm
Dupe
Re: internet speed test by jontera on Thu Jun 18, 2009 6:40 pm
that's from the work system/server.
I'll try the one at home tomorrow
