Frontera Technical Support • View topic - laptop wireless
laptop wireless
laptop wireless by jellybaby on Wed May 27, 2009 9:35 pm
can you change the wireless card in a laptop to improve the connection i have no idea about computers
Re: laptop wireless by Roo on Wed May 27, 2009 11:43 pm
Hi Dave
found this for you, as I am not sure if you can do what you want,..
10 tips for improving your wireless network
If Windows ever notifies you about a weak signal, it probably means your connection isn’t as fast or as reliable as it could be. Worse, you might lose your connection entirely in some parts of your home. If you’re looking to improve the signal for your wireless network, try some of these tips for extending your wireless range and improving your wireless network performance.
1. Position your wireless router (or wireless access point) in a central location.When possible, place your wireless router in a central location in your home. If your wireless router is against an outside wall of your home, the signal will be weak on the other side of your home. Don’t worry if you can’t move your wireless router, because there are many other ways to improve your connection.
2. Move the router off the floor and away from walls and metal objects (such as metal file cabinets).Metal, walls, and floors will interfere with your router’s wireless signals. The closer your router is to these obstructions, the more severe the interference, and the weaker your connection will be.
3. Replace your router’s antenna.The antennas supplied with your router are designed to be omni-directional, meaning they broadcast in all directions around the router. If your router is near an outside wall, half of the wireless signals will be sent outside your home, and much of your router’s power will be wasted. Most routers don’t allow you to increase the power output, but you can make better use of the power. Upgrade to a hi-gain antenna that focuses the wireless signals only one direction. You can aim the signal in the direction you need it most.
4. Replace your computer’s wireless network adapter.Wireless network signals must be sent both to and from your computer. Sometimes, your router can broadcast strongly enough to reach your computer, but your computer can’t send signals back to your router. To improve this, replace your laptop’s PC card-based wireless network adapter with a USB network adapter that uses an external antenna. In particular, consider the Hawking Hi-Gain Wireless USB network adapter, which adds an external, hi-gain antenna to your computer and can significantly improve your range.Laptops with built-in wireless typically have excellent antennas and don’t need to have their network adapters upgraded.
5. Add a wireless repeater.Wireless repeaters extend your wireless network range without requiring you to add any wiring. Just place the wireless repeater halfway between your wireless access point and your computer, and you’ll get an instant boost to your wireless signal strength. Check out the wireless repeaters from ViewSonic, D-Link, Linksys, and Buffalo Technology.
6. Change your wireless channel.Wireless routers can broadcast on several different channels, similar to the way radio stations use different channels. In the United States and Canada, these channels are 1, 6, and 11. Just like you’ll sometimes hear interference on one radio station while another is perfectly clear, sometimes one wireless channel is clearer than others. Try changing your wireless router’s channel through your router’s configuration page to see if your signal strength improves. You don’t need to change your computer’s configuration, because it’ll automatically detect the new channel.
7. Reduce wireless interference.If you have cordless phones or other wireless electronics in your home, your computer might not be able to “hear” your router over the noise from the other wireless devices. To quiet the noise, avoid wireless electronics that use the 2.4GHz frequency. Instead, look for cordless phones that use the 5.8GHz or 900MHz frequencies.
8. Update your firmware or your network adapter driver.Router manufacturers regularly make free improvements to their routers. Sometimes, these improvements increase performance. To get the latest firmware updates for your router, visit your router manufacturer’s Web site.Similarly, network adapter vendors occasionally update the software that Windows XP uses to communicate with your network adapter, known as the driver. These updates typically improve performance and reliability. To get the updates, visit Microsoft Update, and then under Select by Type click Hardware, Optional. Install any updates relating to your wireless network adapter. It wouldn’t hurt to install any other updates while you’re visiting Microsoft Update, too.Note When you go to Microsoft Update, you have two options: the Express Install for critical and security updates and Custom Install for high priority and optional updates. You may find more driver updates when you use Custom Install.
9. Pick equipment from a single vendor.While a Linksys router will work with a D-Link network adapter, you often get better performance if you pick a router and network adapter from the same vendor. Some vendors offer a performance boost of up to twice the performance when you choose their hardware: Linksys has the SpeedBooster technology, and D-Link has the 108G enhancement.
10. Upgrade 802.11b devices to 802.11g.802.11b is the most common type of wireless network, but 802.11g is about five times faster. 802.11g is backward-compatible with 802.11b, so you can still use any 802.11b equipment that you have. If you’re using 802.11b and you’re unhappy with the performance, consider replacing your router and network adapters with 802.11g-compatible equipment. If you’re buying new equipment, definitely choose 802.11g.Wireless networks never reach the theoretical bandwidth limits. 802.11b networks typically get 2-5Mbps. 802.11g is usually in the 13-23Mbps range. Belkin’s Pre-N equipment has been measured at 37-42Mbps.
Good Luck yeah :D
Re: laptop wireless by Krusher on Wed May 27, 2009 11:49 pm
Re: laptop wireless by yaki on Thu May 28, 2009 1:03 am
Re: laptop wireless by Roo on Thu May 28, 2009 11:25 am
Hi Dave :D
Think it depends how far you are away from ... ''The exchange'' think that's what BT call them, but I ain't too sure :wink:
So if you live far away from it then your signal isn't going to be as strong,but I could be wrong on that :oops:
Re: laptop wireless by Frontycustoms on Thu May 28, 2009 7:07 pm
Re: laptop wireless by Roo on Thu May 28, 2009 7:17 pm
ohhhh right sorry :oops: :oops:
I knew it was something :wink: but always thought it was to do with the signal :oh yer: dohhh!
Thanks Mark :dance:
Re: laptop wireless by Valerian on Thu May 28, 2009 7:45 pm
Valerian
Modifications: None yet and i don't really plan to do any. Those days have gone *smirk* but who knows what might happen in the future *grin*.
Re: laptop wireless by ukcobra on Thu May 28, 2009 8:28 pm
Also if you live in a house with very thick walls, you are unlikely to improve things.
The most successful thing I have found is to move the wireless channel away from the default 6 and 10, as most people who live near you use those, and that can have an effect on your signal strength if other devices are also using the same frequency.
That is a quick and easy thing to do, and does n't need anything being taken apart.
Mark
ukcobra
Modifications: 96 2.0 S SWB
Old Man Emu 2" Lift
Mods to fit :
Mods to come:
Winch
