Frontera Technical Support • View topic - memory map onto navman????
memory map onto navman???? by bobbinsjob on Wed May 20, 2009 4:22 pm
I know that the navman s30 delux can be hacked and tomtom software loaded onto it because it runs windows, does this mean that it is possible to load memory map onto it aswell??
And if so, how
Re: memory map onto navman???? by Frontycustoms on Wed May 20, 2009 6:29 pm
Use active sync to sync it with the pc then open MM on the pc n go to mobile device then install MM :wink:
Re: memory map onto navman???? by bobbinsjob on Thu May 21, 2009 8:11 am
think you'll be getting a phone call mate :wink:
Re: memory map onto navman???? by Roo on Thu May 21, 2009 10:08 am
Re: memory map onto navman???? by Rich on Thu May 21, 2009 2:05 pm
my little navman f10 runs mm and iam just trying to get tomtom to run on it now all i need is the maps unlocked :wink: :wink:
this is a good place to have a look round for navman stuff
http://navmanunlocked.forumwise.com/for ... 82cf55e1a5
Re: memory map onto navman???? by bobbinsjob on Fri May 22, 2009 1:28 pm
cheers rich
Re: memory map onto navman???? by alex on Fri May 22, 2009 7:20 pm
Easy once you know how. You will need to have liscenced your MM (or borrowed one) then it will active sync over.
Re: memory map onto navman???? by Frontycustoms on Fri May 22, 2009 8:28 pm
Re: memory map onto navman???? by ricardo1945 on Fri May 22, 2009 9:18 pm
mudcubs4x4.com
ricardo1945
Model: 2.5 TDS Transglobe 5dr
Modifications: none yet prety gd standard looking at lifting it soon though :)
Re: memory map onto navman???? by Frontycustoms on Fri May 22, 2009 10:58 pm
[/quote]
DO TOMTOM DO OFFROADING MEMORY CARDS ??[/quote]
Not really no. U need memorymap for that mate.
Re: memory map onto navman???? by alex on Sat May 23, 2009 8:49 am
Slight hi-jack, but anyone able to put Lanzarote on a pda with tomtom on it? or a tomtomxl?
Re: memory map onto navman???? by john (smifffy) on Sat May 23, 2009 9:55 am
Re: memory map onto navman???? by alex on Sat May 23, 2009 6:23 pm
cool thats me searching the tinternet..
