Frontera Technical Support • View topic - Broadband Techy Advice needed.
Broadband Techy Advice needed. by FUDDY MUCKER on Sun Jan 04, 2009 8:07 pm
Right, having a few issues with SKY Broadband at the moment.
Since I started with them My average speed has been around 6.5 - 7.0 mbps, anytime of day or night
For the past few weeks I've been experiencing very slow speeds, sometimes down to 0.5 mbps.
I initally put it down to the Christmas on line rush affecting the internet. Anyway to cut a long story short It's still running very slow.
Here are some details.
Usually runs at around 7.0 MBPS anytime of day or night
Exchange is about 200 yards from my house.
Router is plugged directly in to socket that enters the house.
Router is connected using ethernet cable.
Have replaced ALL the connection cables to and from the moden with brand new, unopened, and unused ones.
Replaced all of micro filters with brand new ones.
Disconnected all other extensions from the main socket.
Run a virus scan, and a spy ware scan.
Deleted all internet clutter, such as temp files, history etc.
Tested speed using several broadband speed testers, including http://www.Speedtest.net
Also tested speed using wireless connection. Still the same crappy, slow, usless speed.
Just had a major rant and rave at the usless SKY Techy type bloke how gave me a web address to type in to get some details of my router and I got this .....
Modem
ADSL Firmware Version A2pB023o.d20h
Modem Status Up
DownStream Connection Speed 16378
UpStream Connection Speed 764
VPI 0
VCI 38
He pointed out that my modem was recieving speeds of 16 MBPS.....
Yet a speed test reveals this .....
Told him in no uncertain terms that I will detach his head from his body and poo down his neck and that Sky can get stuffed cos I'm going to give my £100 + per month to Virgin Media. (He did'nt even respond to the last two comments !!!!)
So, is Sky giving me the run around and trying to fob me off with BULLSH*T or is there a problem else where ????
I've run out of ideas.
Look forward to some replies.
Re: Broadband Techy Advice needed. by tws7501968 on Sun Jan 04, 2009 8:25 pm
Have you rebooted the router/modem?
Cures mine when this happens. Not sky though.
tws7501968
Model: 2.2i Transglobe 5dr
Re: Broadband Techy Advice needed. by Road Hog on Sun Jan 04, 2009 8:26 pm
Jase,why is it showing your ISP as Easynet on the speedtest ??
Re: Broadband Techy Advice needed. by jellybaby on Sun Jan 04, 2009 8:34 pm
just thought i would join in don't actually understand any of it :?
Re: Broadband Techy Advice needed. by nigelbread on Sun Jan 04, 2009 9:08 pm
I do not trust speedtest net.
4 tests all different.
nigelbread
Modifications: +
Re: Broadband Techy Advice needed. by FUDDY MUCKER on Sun Jan 04, 2009 9:09 pm
Re: Broadband Techy Advice needed. by Alchamist on Sun Jan 04, 2009 9:54 pm
Jase,
If you want, I might be able to pop over one night this week and have a look for you - see if I can sort out what's going on ;)
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: Broadband Techy Advice needed. by fogman on Sun Jan 04, 2009 10:08 pm
broadband speed test sites are a joke and untrustworthy because i never get the same results from any of them :cry:
what if anything have you changed since you were getting 7 mps ?? seems a bit strange if you havent changed anything :?
Re: Broadband Techy Advice needed. by perfectprincess on Sun Jan 04, 2009 10:10 pm
Jase glad im not the only one having problems but at least you have some one close by to lend a hand, hope you sort it :D
perfectprincess
Frontera Goddess
Frontera Goddess
Re: Broadband Techy Advice needed. by Livewire Frontera on Sun Jan 04, 2009 10:23 pm
i heard recently that some cables in some ocean somewhere over Christmas had been severed and that it ws interfering with NET traffic don't know if that could be a possible cause also what spyware remover are you using?? i swear by spybot search and destroy available from http://www.download.com hope this helps
Lee
Livewire Frontera
Re: Broadband Techy Advice needed. by Krusher on Sun Jan 04, 2009 10:25 pm
Yeah spybot is really good and free
Re: Broadband Techy Advice needed. by fogman on Sun Jan 04, 2009 10:29 pm
can you plug another laptop etc in to the modem to compare performance ?
Re: Broadband Techy Advice needed. by FUDDY MUCKER on Sun Jan 04, 2009 10:44 pm
Re: Broadband Techy Advice needed. by Livewire Frontera on Sun Jan 04, 2009 10:46 pm
In that case fuddy me old mate i would say that Mr Murdoch is takin da wee wee out of you
Livewire Frontera
Re: Broadband Techy Advice needed. by FUDDY MUCKER on Sun Jan 04, 2009 10:51 pm
Re: Broadband Techy Advice needed. by Alchamist on Sun Jan 04, 2009 10:54 pm
Sky need to contact BT Wholesale to get them to check the line ..
Jay
Alchamist
Modifications: .
* CB
Re: Broadband Techy Advice needed. by fogman on Sun Jan 04, 2009 10:57 pm
if more than 1 computer is affected then can you could get a new modem [that would be the last thing you can test]from argos install it & try it, if the new modems ok keep it. if theres no difference it must be the line so take the modem back within 12 days & get a refund :wink:
Re: Broadband Techy Advice needed. by FUDDY MUCKER on Sun Jan 04, 2009 10:59 pm
Re: Broadband Techy Advice needed. by Krusher on Sun Jan 04, 2009 11:01 pm
I have got a spare SKY wireless router you are welcome give it a try if you want
Re: Broadband Techy Advice needed. by tws7501968 on Sun Jan 04, 2009 11:03 pm
Don't suppose you might have been downloading large amounts lately, such that an isp might consider to be over your fair share maybe, and throttling your connection as a result?
Not that they do such things of course.....
tws7501968
