Memory Map
Re: Memory Map by bobbinsjob on Thu Feb 17, 2011 1:55 am
I'm gonna need an idiots guide
Re: Memory Map by hipo1024 on Thu Feb 17, 2011 4:18 am
lol should be the same as your PDA....Connect your phone using the USB cable, start up activ sync, set that up so it is talking to your phone. Then start up MM, click on "Mobile Device" then click on "Install Pocket Navigator" then follow the on screen destructions. :P MM (on the PC) will do somthing (I cant remmeber what), then you'll need to finish off the install on your phone, so unlock it/turn on your screen and follow then destructions. Than it should be exactly the same as your PDA.
Reason: removed pointless quote
Re: Memory Map by bobbinsjob on Mon Feb 21, 2011 3:40 pm
problem i have is that my lappy is runnig windows shista and doesnt have active-sync, only windows mobile centre which dont like MM
Re: Memory Map by Wilberforce on Mon Feb 21, 2011 5:16 pm
Can you not get XP running on it, in a virtual machine?
Re: Memory Map by hipo1024 on Mon Feb 21, 2011 5:42 pm
Ive done it in windows 7 with windows mobile centre, just connected it, leave it running in the background and start up MM, then use it as you would normally. I havnt actualy used active sync yet lol so I'm more at home with windows mobile centre.
Re: Memory Map by country_Est on Mon Feb 21, 2011 7:25 pm
Bobinsjob,
I have Vista on my home PC and XP on the lappy and MM is happy with both of them and connects to the same PDA with MM.
Trev
2000 Frontera 2.2 DTi Ltd
country_Est
Vehicle Name: panserbjørne
Re: Memory Map by Drift on Mon Feb 21, 2011 8:33 pm
Reload active sync, or just use the memory card into the pc, its much faster to load maps that way anyway :wink:
Re: Memory Map by hipo1024 on Mon Feb 21, 2011 9:26 pm
yeah that'll work for loading maps, but you'll need the phone connected (and working) to install MM.
Re: Memory Map by BadBoy on Mon Feb 21, 2011 10:40 pm
Out of interest, what are you using to run it on Android Ste? I'm using MM Tracker on my HTC Desire (non HD)
Skype Username: paul.bush21
Re: Memory Map by Drift on Mon Feb 21, 2011 11:02 pm
Yup the sane MM Tracker :wink:
Re: Memory Map by Rich on Mon Feb 21, 2011 11:49 pm
where did you get that from steve :wink: :wink:
Re: Memory Map by Drift on Mon Feb 21, 2011 11:57 pm
:wink: :lol: :lol:
Re: Memory Map by BadBoy on Tue Feb 22, 2011 8:53 pm
Re: Memory Map by Rich on Tue Feb 22, 2011 9:37 pm
ive got it mate i was having a joke with steve :D :D
