Frontera Technical Support • View topic - memory map ??????????????????
Re: memory map ?????????????????? by Drift on Mon Jan 26, 2009 1:53 am
Yours dont run windows mobile does it ark, would be good if you could tell me how it loads on other operating systems :wink: :wink: off forum
Re: memory map ?????????????????? by Sir-Doris on Mon Jan 26, 2009 2:20 am
According to MM its windows only. Either Win XP or Win Mobile. Apparently MAC users could use emulation software to run it but I doubt Linux users would be so lucky.
Re: memory map ?????????????????? by Frontycustoms on Mon Jan 26, 2009 12:42 pm
No mate it dont. I meant the mobile version as in the one to go onto the pda Ste. But the phone has Navtech mapping so i might try n see if the maps them self work but doubt they will :(
Re: memory map ?????????????????? by Drift on Mon Jan 26, 2009 7:25 pm
Does anyone else have problems running the full area maps on their pds?
What I mean is, if I load the visible map from the pc screen to the pda no matter what size it works, but if I send the whole map area say Region 3 it wont work on the pda you get an error message.
Re: memory map ?????????????????? by Sir-Doris on Mon Jan 26, 2009 7:43 pm
According to the help file the largest map you can open on a pda is 400megabytes. Never tried uploading one that size as I just add maps as I need them.
Re: memory map ?????????????????? by Drift on Mon Jan 26, 2009 7:46 pm
Most are around 340MB :?
Re: memory map ?????????????????? by john (smifffy) on Mon Jan 26, 2009 8:08 pm
on my HP pda ive got 2 area's 1 is 394mb central england south i have a few bits ive add before i transfered to pda and the other is 306mb south west england both seem ok
i can switch between tom tom & MM with no prob
Re: memory map ?????????????????? by Drift on Mon Jan 26, 2009 8:18 pm
It does my noggin in, I was moving maps about and its just started happening :?
No problem switching between applications though.
Re: memory map ?????????????????? by jellybaby on Mon Jan 26, 2009 8:44 pm
i was looking at the pdas some of you have had the nav man will have to wait a month of two and see whats around once my cash is sorted
Re: memory map ?????????????????? by Jools on Mon Jan 26, 2009 10:13 pm
Julian, Frontera A 2.0 Motorsport Safety Truck
2M0 VXL Amateur Band Radio
Vulture 20 Motorsport Safety Radio
Jools
Vehicle Name: Blue
Modifications: 1.5" Milner Body Lift
31" Macho Tyres OR
31" ATs for decent mileage!
Stripped rear end
Rear recovery points
AFFF Fire Extinguisher
First Aid Kits
Internal wiring redone
Various radio equipment
Roof mounted Amber beacon
Roof mounted Hi-lift Jack
Sirens & PA system
Dash mounted Tablet PC with Memory Map
Re: memory map ?????????????????? by Frontycustoms on Mon Jan 26, 2009 11:35 pm
I've got MM runnin on a HP RZ1710 pda . Patched it to run a memory card bigger than a gig, put in a 2 gig n put on regions 4,5 & 6 tested it n no problems.
P.S. Cheers Ste. :wink:
Re: memory map ?????????????????? by Drift on Tue Jan 27, 2009 12:53 am
No prob Mark, its on an 8gig card but just wont run the full 340MB files :? , I t did run but has decided it doesnt want to now :roll:
Re: memory map ?????????????????? by Frontycustoms on Tue Jan 27, 2009 12:58 am
Is 8 gig the bigest card the pda will support Ste. Tell ya y i ask, my N95 had an 8 gig card n it was way slow, put a 4 gig init n way quicker mate. It would only support a max of 4 gig ya see mate. :wink: :roll:
Re: memory map ?????????????????? by Drift on Tue Jan 27, 2009 1:06 am
Most people run the 8gig but it can go up to 16gig :shock:
Im only using 2gig with 15 albums on and copilot :lol:
Re: memory map ?????????????????? by Frontycustoms on Tue Jan 27, 2009 10:03 pm
Re: memory map ?????????????????? by bobbinsjob on Thu Jan 29, 2009 10:35 pm
right, I've got me a PDA, but i aint got a clue how to get MM and the overlays onto it. Can someone talk me through how to do it please? :?
Re: memory map ?????????????????? by andysd1 on Thu Jan 29, 2009 11:06 pm
Re: memory map ?????????????????? by Drift on Thu Jan 29, 2009 11:39 pm
Set MMAP up on pc then go to the menu at the top go to mobile device, make sure its connected via active synch then hit install pocket navigator, when it asks on the pda screen load it to device.
Let us know when you get that far.
Re: memory map ?????????????????? by cheekychick on Thu Jan 29, 2009 11:42 pm
Re: memory map ?????????????????? by Frontycustoms on Thu Jan 29, 2009 11:59 pm
