// Frontera Technical Support • View topic - 2.8/3.1 4JB1T/4JG2 ENGINE PARTS WANTED
Frontera's/Cars etc all adverts will be deleted after 28 days unless they are renewed
Postby bhcalcutta on Thu Jan 18, 2018 3:41 pm
Has anybody got a knackered 2.8 or 3.1 Isuzu engine kicking about that they might be willing to sell some parts off?
I basically need the bottom auxillary belt pulley, the flange that sits behind this, the crankshaft timing gear, woodruff key & bottom timing cover.
I'll gladly buy these parts off anyone, or a full engine if close enough.
Any help will be greatly accepted & rewarded
BH (Pat)
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Re: 2.8/3.1 4JB1T/4JG2 ENGINE PARTS WANTED
Postby bhcalcutta on Mon Jan 22, 2018 5:31 pm
To clarify, the part I urgently need is pictured below, along with the woodruff key if possible
bhcalcutta
Intek CB
Kenwood head unit
avm manual lockers
Trooper clutch
egr delete
Postby snapper on Thu Jan 25, 2018 11:49 pm
I may well have one, see message
Postby bhcalcutta on Fri Jan 26, 2018 6:15 pm
Thanks Frank, I've replied.
Part now acquired, so this can be deleted
bhcalcutta
Intek CB
Kenwood head unit
avm manual lockers
Trooper clutch
egr delete
Postby snapper on Fri Jan 26, 2018 10:48 pm
And I just stripped the engine from the flywheel end to get the thing off lol....
Return to Fronteras Wanted
