// Frontera Technical Support • View topic - Heater Matrix
Heater Matrix
Heater Matrix
Postby homely68 on Mon Oct 24, 2016 5:35 pm
Hi I was just wondering if there is any information about changing your Heater Martrix online. I wanted to try and replace mine myself, but heard it isn't easy. A friend of mine, does my work normally and he keeps the cost as low as possible. However he told me that it would be the time involved with this. Also how can you be sure that it is the Matrix that has gone and not something else, when you aren't getting any heat. Thanks in advance and sorry if I posted in the wrong place. :cry: :roll: :)
homely68
Re: Heater Matrix
Postby mickh on Mon Oct 24, 2016 9:27 pm
Is yours an A or B series? What makes you think the matrix has gone, are you losing coolant or is just not blowing hot?
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: Heater Matrix
Postby dave1966 on Tue Oct 25, 2016 12:04 am
If the matrix isn't leaking and your not losing any coolant, then the coolant system could have air inside and that is an easy fix.
My first Frontera (1993 2.4i LWB). viewtopic.php?f=46&t=27691&p=309004#p309004
Comments on my (1993 2.4i LWB). viewtopic.php?f=32&t=41426
My present Frontera (1999 2.2 DTI LWB). viewtopic.php?f=46&t=52970&p=568393#p568393
Comments on my (1999 2.2 DTI LWB). viewtopic.php?f=32&t=52971
R.I.P Sable!(2005 to 2013)
dave1966
Vehicle Name: kNoCkerS
Modifications: 60 amber LED light strips on each side step, 12 amber LED light strip above front number plate, Neon underbody LED light kit, Red LED marker lights fitted to rear mud flaps,Rear view reversing camera,Mondeo v6 Powerflow rear twin exhaust boxes,FOG stickers.
Re: Heater Matrix
Postby bleu boy on Sat Oct 29, 2016 3:38 pm
Heater matrix is easy to do bud am sure theirs a wee bit plastic on the end you have to snap off where heater matrix sits in but you don't need it s the heater matrix pips hold it in you can take glove box out am sure so you don't have to strip dash on it half hour job :D
bleu boy
Re: Heater Matrix
Postby mickh on Sat Oct 29, 2016 7:00 pm
Wow half hour job, like to watch that. :shock:
mickh
Front winch.
CB radio.
Re: Heater Matrix
Postby aredee on Sat Oct 29, 2016 7:46 pm
i thought half a week not 1/2 hr
aredee
Vehicle Name: Bubbles
Re: Heater Matrix
Postby frontster on Sat Oct 29, 2016 8:54 pm
Not a difficult job, but certainly not in half hour.
frontster
Modifications: No mods.
Re: Heater Matrix
Postby Fatbaz on Tue Nov 01, 2016 12:23 pm
Hi
Ease of the job will depend on whether you have an A or B series. If it's an A series it'll take best part of a day as you have to take the whole dash out to get the heater box out to change the matrix (been there done that). As for the B series, I don't know as I haven't done one.
As to whether it is the matrix block you have to diagnose, I trust the cooling system doesn't loose water and never has, does the engine temp gauge run at the normal hot/warm place, do the hoses and rad get hot. Does the heater blow cold or tepid/warm. If you can answer yes to most of the above then you'll probably find the matrix is blocked. You could try back flushing it using a hose pipe or even running the engine with a rad cleaner fluid (bleach) to break down the crud. Failing that you need to change the matrix.
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: Heater Matrix
Postby homely68 on Mon Nov 14, 2016 9:03 am
Hi sorry i haven't thanked you all for your replies. Just wasn't sure how to respond. The thing is now that my daughter who owns her beloved Frontera Sport and it is a 1998/99 A I think, has been told that when the heating isn't working the head gasket is on it's way out and it wont be worth repairing. It runs well and the body work is excellent for it's age. She couldn't afford to take it to a garage, as it would cost more than her Frontera is worth most probably. If the head gasket is on it's way out, then why no other problems.
homely68
Re: Heater Matrix
Postby homely68 on Mon Nov 14, 2016 8:52 pm
I have just found out that the heater comes on and is hot when the engine gets hot but then it goes tepid again. Does this give more clues. My daughter really wants to keep it but has been told its not worth it if it is the head gasket.
homely68
Re: Heater Matrix
Postby Robfog on Mon Nov 14, 2016 10:01 pm
Could be an air lock..........
Robfog
Re: Heater Matrix
Postby mickh on Wed Nov 16, 2016 9:46 pm
Forget about the head gasket and start with the easy things first. Air lock, thermostat, water pump. Flush the rad and the heater matrix through, fill up with the correct anti freeze mixture and bleed the system. Go for a spin and see what happens.
mickh
Front winch.
CB radio.
Return to New Members
Users browsing this forum: Google [Bot] and 1 guest
