// Frontera Technical Support • View topic - green laning kit ?
green laning kit ?
green laning kit ?
Postby gazza1591 on Sun Dec 11, 2011 2:34 pm
Hi all
i have started to get some kit for the green laning and off road days but was just wondering if there are any 4x4 shops online
which sell good quality kit ? i have a high lift jack and toe rope plus a selection of tools all ready but still need some more bits :D
gazza1591
Vehicle Name: the tank
Modifications: none as yet but plenty to come
Re: green laning kit ?
Postby jason on Sun Dec 11, 2011 2:49 pm
There is a 4x4 shop on the droitwitch Road :wink:
http://www.mm-4x4.com/contact-us-3-w.asp
Postby gazza1591 on Sun Dec 11, 2011 3:47 pm
cheers jason nice one and local aswell
are there any more online stores any of you use/have used in the past
let the spending begin :drink:
gazza1591
Postby Biffo on Sun Dec 11, 2011 10:48 pm
Try Winch Solutions near Haydock ( J23, M6 http://www.winchsolutions.co.uk) I've bought plenty from them, all good stuff, and usually cheaper than most you find.
Make sure that you've got good recovery points both on the front & rear of the truck.
As a minimum I'd go for a 4 mtr long strap, and a 2 mtr long strap. at least 3 good quality D shackles, (If you have a towbar, get one or two that will just slip over the ball.)
A spade, something to put the jack on to stop it sinking when the ground isn't hard.
Tools, jack, spare bulbs, oil etc should be the norm anyway.
After that, you can build up as you find that something would have come in handy. Some people swear by waffle boards, I have a pair but have never needed to use them yet, on the other hand I also carry a chainsaw, and tend to need it a few times a year.
Personally I don't like the high-lift jacks, they can be very dangerous, I have a good wide based trolley jack that gets used for wheel changing.
Biffo
Postby horses45 on Thu Dec 15, 2011 11:36 am
SnowManWales wrote:would this be something to consider for greenlaning?
Multi-Function Outdoor Camping Shovel Spade Tools
Im not sure about that as it looks not to hard wearing but i could be wrong i like the old army shovels thats what i normally have in the back of mine
Postby Fatbaz on Thu Dec 15, 2011 1:48 pm
Have to agree with Horses, that kit looks a bit woos! Digging out with a short handle will do your back. The military spades are good as long as you get one with a sound handle or convert it to a steel tube as I have on mine (cold to the touch but won't snap).
The key to driving off road isvehicle prep and mods together with drivivg skills, been many a place in 2wd where a full on 4x4 has failed.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
