by Drift on Mon Aug 24, 2009 11:36 pm
Taken from the CRAG website. As the state of the first, rocky, section of this lane, by the stream, is getting increasingly worse, could we all consider avoiding it until repairs have been effected? On Saturday 22nd, I am aware of three vehicles ending up in the stream, and on Sunday 23rd, when it was wet, more of the same happened. In effect, it is now happening EVERY weekend, and the house occupants are getting increasingly angry about their water supply being polluted on a regular basis by 4x4 drivers, and quite understandably, too! Wrexham Council are aware of the situation, and are fully behind our proposals to repair the roadway. Paul is currently liaising with them to get something arranged (so, there will shortly be a call for volunteers!!! ) There are other routes over into the Valley that could easily be incorporated into route planning, so, hopefully we could all do that until repairs have been completed? The condition of the road from above this section over to Llanarmon DC is fine, and there's no reason why that bit should be affected.
Just a thought but, if in agreement, could this be publicised on other forums so that usage can be reduced as much as possible, and we are seen to be making an effort?
Land Ranger 125. GR 170370. Regards, __________________ Hoodoo, '03 Niva si.
Link to the thread, feel free to post your concerns. http://www.crag-uk.org/forum/showthread.php?t=2771 Thank you for reading.
- The Man-ual
Tinkered to it's practical limits but understated, though shockingly cool (do you know her?). She is nicccccceeee ;-)
Skype: | |
by Sir-Doris on Tue Aug 25, 2009 1:24 am
Agreed, It was skipped out of my last run over that direction for that very reason.
Good posting, unfortunately CRAG registrations seem to be closed so cant post anything there.
I also drink Port and I'm not ashamed to say it! Me Truck
- Sir Dong
265/75/16 Marix Lions Pro-Comp Steering Stabiliser Rough Country Shocks + 5" Suspension Lift UCA Ball Joint Spacers + Low Profile Bump Stops Stainless Extended Braided Brake Lines 1.5" Body Lift CB Lowered Front Diff Hangers Grooved and Dimpled Front Brake Discs Front and Rear Recovery Loops Petrol Cap on a String Secondary Air Injection System Removed Removed Front ARB
by andysd1 on Sat Sep 19, 2009 9:22 pm
do we know if work has started on this
- Lord frontera
by furio on Mon Nov 16, 2009 8:18 pm
Anyone been up there and seen the repairs? Pics even better
furio
- GURU
CB Manual Cooling Fan Switch Snorkel Old Man Emu Suspension lift Roof lights Raised Axle Breathers
by andysd1 on Mon Nov 16, 2009 9:43 pm
takes a bit of excitement away, but well done, looks cool
- Lord frontera
by headbanging on Tue Nov 17, 2009 8:27 am
Cor blimey crickey!
When you compare that pic to my avatar, you can see taht they ahve done a real proper job on it!
For what it's worth it was worth all the while It's something unpredictable but in the end is right I hope you have the time of your life
headbanging
- GURU
wound up torsion bars (2") flipped top ball joints, viscous fan removed, and replaced with an electric fan,(switch in cab) roof light pod cut down nudge bar with two long range fogs blue-tooth CD player she is wearing a set of sport wings and a B- series bumper modified side repeaters smoked tail lights removed spare wheel holder (swing arm) uprated turbo hoses
Skype: | |
by furio on Wed Nov 18, 2009 8:13 pm
Well its still a good lane whether or not and as Drift said, at least its still driveable. Thanks for digging that pic out Drift
furio
- GURU
