// Frontera Technical Support • View topic - Helpfull info needed
Postby Paddymc on Thu Dec 28, 2017 7:51 pm
Was wondering if anyone could tell me where to get a Bush for the rear stabilizing bar for a 01 plate lwb 2.2dti it's the side that bolts on to the diff tryed vauxhall but they don't supply parts
Paddymc
Re: Helpfull info needed
Postby bhcalcutta on Fri Dec 29, 2017 12:44 am
Do you mean the bushes for the stabiliser (roll) bar, sits behind #4 on this image
Or the bushes for the panhard rod, #16 in this image
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Postby vauxsqueeks on Fri Dec 29, 2017 4:14 pm
I have bought some bushes through these guys in the past:
https://www.milneroffroad.com/
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
Postby Paddymc on Fri Dec 29, 2017 4:27 pm
The ones on the second image hopefully for both ends but if not then the one that bolts to the axel side . I will check milners offroaders as well thank both off you for quick reply
Paddymc
Postby bhcalcutta on Fri Dec 29, 2017 7:24 pm
Paddymc wrote:The ones on the second image hopefully for both ends but if not then the one that bolts to the axel side . I will check milners offroaders as well thank both off you for quick reply
These are the fellows you want then HERE, FULL SET for all link assemblies and the panhard rod
bhcalcutta
Intek CB
Kenwood head unit
avm manual lockers
Trooper clutch
egr delete
Postby vauxsqueeks on Tue Jan 02, 2018 10:29 am
be very cautious when undoing the nuts on the Axle. they have a tendency to sheer off and if you do this then its a new axle unless you can redneck it.. Use plenty of plusGas / wire brush and be careful when removing..
Specifically nut 13 on the rear right side of the Picture ( on car Near Side Rear ).
Now Gone
vauxsqueeks
Users browsing this forum: Google [Bot] and 2 guests
