Postby stretch on Sun Jan 28, 2018 11:16 pm
Glad you sorted it mate
Postby jmc on Sun Feb 11, 2018 10:09 pm
Today I tried to free up the bumper cable to close the bonnet again. Think it may need a new cable it's very stiff.
Earlier this week I had trouble with the tailgate glass not closing. Added a washer to each bolt on the catch on the glass to push it out a bit more so it catches now in the one in the door.Also put on a new rear rubber bump stop.
jmc
Postby snapper on Mon Feb 12, 2018 12:23 am
jmc wrote:Today I tried to free up the bumper cable to close the bonnet again. Think it may need a new cable it's very stiff.
Isn't the catch on the door adjustable?
Postby snapper on Tue Feb 13, 2018 12:47 am
Just dropped off Truck at the Garage ready for it's MOT at 09:00 tomorrow. To be honest it's been a bit of a mare with it over the last week, the knackered engine had to come out and the newer working one in, a simple enough job that for some daft reason I've been putting off for the last 6 months or so. Anyway, it's done now and seems to be running sweet. Shame the same cant be said for the ******* heater! Guess that'll be the next job once the MOT is out of the way.
Postby jmc on Tue Feb 13, 2018 10:54 pm
Hope mot goes well!
I didn't realise the catch is adjustable I'll have to have a look tomorrow. :oops:
jmc
Postby stretch on Tue Feb 13, 2018 11:07 pm
fingers crossed for the mot gods
Postby snapper on Wed Feb 14, 2018 12:33 am
And we have the MOT results in....
Date tested: 13 February 2018
Fail
Mileage: 287,590 miles
Reason(s) for failure:
1. Offside Front Windscreen washer provides insufficient washer liquid (8.2.3)
2. Nearside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
3. Offside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
4. Nearside Front Ball joint has excessive play swing arm. Marked with yellow chalk. (2.2.B.1f)
5. Nearside Rear Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
6. Nearside Front Outer Track rod end ball joint has excessive play (2.2.B.1f)
7. Nearside Front Front wheel bearing has excessive play (2.5.A.3c)
Advisory notice item(s):
1. Offside Front Brake servo corroded but not excessively weakened (3.6.A.2b)
2. Offside Front Inner Track rod end ball joint has slight play (2.2.B.1f)
3. Offside Rear Shock absorber has a slightly worn bush (2.7.4)
4. Offside Front Front wheel bearing has slight play (2.5.A.3c)
5. Nearside Front Road wheel slightly damaged (4.2.A.1a)
6. Nearside Front Tyre worn close to the legal limit 2mm (4.1.E.1)
:axe:
Could have been worse considering the age of the truck, the mileage and it's normally hard life! Although all very simple stuff I have to admit to letting the garage sort it out :oops: It's cold in the yard and I'm just too busy to get on with it between now and Sat when it's needed for a trip out so the MOT place got a right shock when they were told to get on with it.
Postby snapper on Wed Feb 14, 2018 8:21 pm
Wahay.... Truck lives to drive another day!!!! Just took it for a spin round town after picking it up from the Garage post MOT c/w new 12 month ticket :party:
Oddly enough it drives completely different to the XC70 that's been the current daily driver for the last 6 months or so, the trucks got an extra pedal for starters and this weird stick thing that you have to stir around for gears :?
Postby stretch on Wed Feb 14, 2018 8:46 pm
nice one always a good feeling when you get the new ticket.
Postby snapper on Wed Feb 14, 2018 11:13 pm
stretch wrote:nice one always a good feeling when you get the new ticket.
And, on the odd occasion quite miraculous!
Postby Retro Pedro on Thu Feb 15, 2018 3:01 pm
snapper wrote:Wahay.... Truck lives to drive another day!!!! Just took it for a spin round town after picking it up from the Garage post MOT c/w new 12 month ticket :party:
Nice one Frank
Serves the MOT buggers right regarding some of the stuff, especially windscreen. Probably just new blades?
Postby snapper on Thu Feb 15, 2018 8:44 pm
What served them right was taking all day to get the steering idler arm separated from the idler.... I did tell them they might have 'issues' doing it but no, they said it would be easy.....
If the truth were to be known I really couldn't be arrsed to get under it again this week and I wanted it running by the weekend. Plus I've changed those things before and they're always a head ache to do
Postby Furryroo on Wed Mar 07, 2018 12:25 pm
Furryroo
Vehicle Name: Tonka
Modifications: Standard
Postby fudge on Wed Mar 14, 2018 5:49 pm
worked out i may need a new engine :evil:
but this means i can now play with the engine :twisted:
Postby Furryroo on Wed Mar 14, 2018 11:07 pm
fudge wrote:worked out i may need a new engine :evil:
Drop a Redtop in it!
Furryroo
Vehicle Name: Tonka
Postby ding on Thu Mar 15, 2018 7:59 pm
Refitted the clutch master cylinder after a rebuild, went to bleed it, snapped the bleed nipple flush to the thingy half way down ffs Dont know what it's called to find another :lol:
ding
Postby fudge on Fri Mar 16, 2018 9:07 am
well i was thinking bigger then a red top :twisted: :twisted: :twisted: :twisted:
Postby bhcalcutta on Fri Mar 16, 2018 7:40 pm
This could be interesting
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Postby fudge on Fri Mar 16, 2018 8:11 pm
I may have something in the pipeline...
I did look at supershargjng it too, but found when that is done the engin has problems with getting too hot
Postby snapper on Sat Mar 17, 2018 10:27 pm
ding wrote:Refitted the clutch master cylinder after a rebuild, went to bleed it, snapped the bleed nipple flush to the thingy half way down ffs Dont know what it's called to find another :lol:
It's an Hydraulic Damper, not fitted to all models apparently and is used to assist in progressive take up of the drive.
