Postby Panzerwomble on Wed Aug 23, 2017 9:04 am
Replace the sagging and frankly quite disgusting headliner . Thanks to Rifleman's "how to "guide , made it a lot more straightforward than having to work out what needed removing to achieve this . Comes out and and goes back in just like the gent says :D
Didn't help though that a previous owner had used builders foam through the light fittings to try to glue the liner to the roof ....!!!######!!!
Word of advice though , the liner needs a lot of care when removing as it is quite flimsy and could easily snap, I did its single handed but two would have been easier .
Now have a cream liner instead of the original grey ,which is a lot brighter inside all for 13 quids worth of leatherette and a can of spray adhesive . :dance:
Panzerwomble
Vehicle Name: Frontosaurus
Modifications: Debadged, repainted Bundeswehr Green, 3" lift, numberplate relocated to back door, Shogun wheels
Postby dave1966 on Tue Sep 05, 2017 12:28 am
Drove it from Conisbrough Doncaster back to Scotland up the A1 (M) after being on holiday with the caravan.
My first Frontera (1993 2.4i LWB). viewtopic.php?f=46&t=27691&p=309004#p309004
Comments on my (1993 2.4i LWB). viewtopic.php?f=32&t=41426
My present Frontera (1999 2.2 DTI LWB). viewtopic.php?f=46&t=52970&p=568393#p568393
Comments on my (1999 2.2 DTI LWB). viewtopic.php?f=32&t=52971
R.I.P Sable!(2005 to 2013)
dave1966
Vehicle Name: kNoCkerS
Modifications: 60 amber LED light strips on each side step, 12 amber LED light strip above front number plate, Neon underbody LED light kit, Red LED marker lights fitted to rear mud flaps,Rear view reversing camera,Mondeo v6 Powerflow rear twin exhaust boxes,FOG stickers.
Postby lee771 on Thu Sep 07, 2017 6:36 pm
Put a railway sleeper through the windscreen :oops: :oops:
Have now bought a trailer lesson learnt
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Postby Panzerwomble on Thu Sep 28, 2017 10:45 am
Replaced all the hardened PVC fuel line from pump to tank , noticing along the way that they had been accidentally swapped over at some point , so the return was going in the feed . Seems to have made no difference to the running . Cold starts are still difficult, new glow plugs on the way .
Panzerwomble
Postby Dooley on Mon Oct 09, 2017 10:33 am
I blanked off the EGR valve as my fronty was going sluggish, blowing black smoke ect. Blanked EGR off and she's sweet as a nut.
Dooley
Model: 2.5 TDS Sport 3dr
Vehicle Name: Beast
Postby fudge on Sat Oct 14, 2017 7:50 am
put the duck in for mot...
only failed on 12 points and 4 were the head lights..
not too bad for sitting for over 6 months mot moving
Postby fudge on Sat Oct 21, 2017 12:11 pm
yesterday i recieved the parts needed for the mot, so started on them last night....
forgot how errm fun the ball joints are to change.... but only now down to 4 things left to do, just waiting for the weather to settle down
Postby bhcalcutta on Thu Oct 26, 2017 5:15 pm
Ran the truck in for MOT, as I'd forgotten it expired 13 days ago :oops:
And it sailed through, with just a few advisories :dance:
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Postby jmc on Thu Oct 26, 2017 8:30 pm
Went out in it loaded with tools to carry on installing some gates in the middle of Canterbury.
This is only possible because much to my astonishment and delight it only needed the silencer and tailpipe renewing to pass its mot.
My mechanic said " it lives to fight another day".
Really pleased to have it hopefully for another year on the road.
jmc
Postby FronteraBob on Fri Nov 03, 2017 8:23 pm
Fitted heated leather seats all for the sum of £40 very happy camper :D
When words become violence, what could be better than silence.....
FronteraBob
Vehicle Name: Red Devil !
Modifications: Zero....
Postby Liam66 on Wed Nov 22, 2017 10:09 pm
Fitted a 20" light bar and had a new set of tyres fitted.
Liam66
Postby bhcalcutta on Wed Jan 17, 2018 6:10 pm
Killed it!!! :cry: :cry: :cry:
bhcalcutta
Intek CB
Kenwood head unit
avm manual lockers
Trooper clutch
egr delete
Postby jmc on Wed Jan 17, 2018 9:09 pm
What happened?
jmc
Postby stretch on Wed Jan 17, 2018 9:22 pm
bhcalcutta wrote:Killed it!!! :cry: :cry: :cry:
what ya done?
Postby bhcalcutta on Thu Jan 18, 2018 3:35 pm
what ya done?
Well, the flange that the bottom pulley bolts to shattered, got carried round by the timing belt until it got jammed between the cam pulley & water pump.
1 stripped belt
1 bent push rod
a shattered pulley flange that I can't find anywhere
and a sheared bolt in the crankshaft
bhcalcutta
Intek CB
Kenwood head unit
avm manual lockers
Trooper clutch
egr delete
Postby furio on Sun Jan 21, 2018 9:18 pm
Gutted for you mate
furio
Manual Cooling Fan Switch
Old Man Emu Suspension lift
Roof lights
Raised Axle Breathers
Postby snapper on Fri Jan 26, 2018 12:13 am
bhcalcutta wrote:
what ya done?
1 stripped belt
1 bent push rod
Check PM's
Postby bhcalcutta on Fri Jan 26, 2018 6:14 pm
Thank Frank, I've replied
bhcalcutta
Intek CB
Kenwood head unit
avm manual lockers
Trooper clutch
egr delete
Postby snapper on Fri Jan 26, 2018 11:33 pm
Mmmm
What have I done to the thing today?
Finally (6 months late) got round to getting the 3.1 c/w hole in sump out of the truck ready for a wee bit of cleaning up of the engine bay and some remedial welding in there while the noisy rattly thing is out of the way and then another lump will be going in.
Aim is get it in, the truck MOT'd and back on the road by the 10th of Feb.
Jobs to do...
Gearbox off
Old engine out
Service on the newer engine (new oil pump, cam belt, water pump)
Split gearbox/transfer box, check bearings and re-assemble.
Clean up engine bay, re-route hoses/pipes and repairs as needed.
Newer, serviced engine in, connect bits up.
Gear box in, replace prop shafts.
Replace N/S front wing.
Replace brake shoes.
MOT....
Postby bhcalcutta on Sun Jan 28, 2018 9:50 pm
bhcalcutta wrote:
what ya done?
1 stripped belt
1 bent push rod
Spent the day putting the beast back together. All sorted now, but I think it's going to have to retire from daily duties soon
bhcalcutta
Intek CB
Kenwood head unit
avm manual lockers
Trooper clutch
egr delete
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
