// Frontera Technical Support • View topic - Fronty4x4spares...Quality Used Parts, rapid delivery.
Re: Fronty4x4spares...Quality Used Parts, rapid delivery.
Postby Ash2.2dti on Fri Feb 07, 2014 9:41 pm
gregster wrote:
Ash2.2dti wrote:after a back door tailgate gasket seel if you have one?
If it the top seal on the tailgate you need, or the one that goes around the whole boot opening?
the whole boot opening.
Ash2.2dti
Vehicle Name: Green one
Modifications: None as of yet
Postby gregster on Fri Feb 07, 2014 11:42 pm
I will have a look for you on Monday and see if we have a good one. :wink:
Postby Team Fragglerock on Sat Feb 08, 2014 11:04 am
Thanks for the prompt and great service. Clutch master is working a treat, can't thank you enough. From now on you guys will be my first port of call.
Team Fragglerock
Team Fragglerock
Registration Year: 2002/52
Vehicle Name: Das Boot
Modifications: 2" lift
31" tires
Postby johnc1 on Sat Feb 08, 2014 4:09 pm
Hi, don't know if you guys can help ... but never know if I don't ask.
Only ever had one key fob for my 'B' 2.2i petrol RS sport.
Now it's recently ceased operating the alarm/immobiliser enable/disable. Bought a repair kit off of ebay (I can solder). Unfortunately, with new microswitch on the pcb and new battery fitted ... absolutely nothing. Still doesn't operate the enable/disable function.
I don't enjoy driving with the alarm blaring and hazards flashing ... do you have a solution for this (e.g. replacement key fob + receiver I can get fitted ... and cheaper than paying the local Vauxhall dealer up to £150 for a new key fob)?
If so, could you and would you accept a set of spare 5 x 16" 5-spoke alloy wheels, as taken from an "A" (4 wheels only, one with a good tyre), in part or full payment?
Or can you tell me how to disable the alarm and immobiliser while I save up for a new dealer-supplied key?
Cheers,
John
johnc1
Postby Ash2.2dti on Sun Feb 09, 2014 10:13 am
gregster wrote:I will have a look for you on Monday and see if we have a good one. :wink:
Thank you.
Ash2.2dti
Postby gregster on Sun Feb 09, 2014 11:41 am
Team Fragglerock wrote:Thanks for the prompt and great service. Clutch master is working a treat, can't thank you enough. From now on you guys will be my first port of call.
Team Fragglerock
:thumbup: :thumbup: :thumbup:
Thats what we want to hear :drink:
Postby gregster on Sun Feb 09, 2014 11:42 am
johnc1 wrote:Hi, don't know if you guys can help ... but never know if I don't ask.
Cheers,
John
What year is your car please John?
Postby Shaunylnk on Sun Feb 09, 2014 6:08 pm
hello Greg
I need a 2.5 Tds top rad hose. (Priority)
Top intercooler hose
The later A series dash clock
And some proper frontera floor matts if you have any?
And some original spot lights
A series bullbars
The main thing is the rad hose the rest would be useful cheers bud
Shaunylnk
Vehicle Name: Cranky frankie
Modifications: Egr removed
Cold start binned
2" body lift
2" suspension lift
31" ctrax and 33" BFG AT for the summer
Broken in two places driver seat
Cut down bull bars
Postby johnc1 on Mon Feb 10, 2014 1:39 pm
Cheers,
John
Hi gregster,
It's a 2000 model ("X" plate).
As a matter of fact and in a final act of desperation, I had one more try with the original alarm remote and used the old trick of wedging a piece of card in the fob housing to keep the battery holder pressed against the pcb ... and hey presto ... the bl@@dy thing decided to work again! Only a semi-permanent repair, but will do for now.
I'd still like to look into obtaining a spare key/2-button alarm fob though.
Next problem is that I didn't receive a record of the key number (or immobiliser code) when I bought the car, to assist with that.
Thanks,
John
Reason: Removed off topic part
johnc1
Postby gregster on Tue Feb 11, 2014 12:24 pm
Shaunylnk wrote:hello Greg
A series bullbars
Hiya.
Havent got a top hose at the mo, or the 2.5 intercooler hose, we only have the one 2.5 at the mo which is an arden blue shorty and its way too good to break so will be repaired and sold complete.
Thats the only facelift we have also, but can keep an eye out for a dash clock.
We have a really good set of genuine LWB matts, including the centre rear one which is normally missing.
Have a steel bullbar which is very very tidy and have various genuine lights depending if you wanted the early bosch type ones, or the later black plastic ones.
Give me a ring, or pop down and we'll sort something out fella.
All the best
Greg
Postby gregster on Tue Feb 11, 2014 12:37 pm
Cheers,
John
Hi gregster,
Thanks,
John
Will keep an eye out for a spare key, but its probably unlikely we will find one as they would normally go with the ecu sets, but you never know we might get a car with an ecu fault so we can separate.
Postby rippa2k on Wed Feb 12, 2014 11:20 am
Hi,
Still after an Autobox for a 2000 V6 3.2.
Any chance of one being available?
My friends call be Hadoken, because I'm Down Right Fierce
rippa2k
Vehicle Name: Metal Beefalo
Modifications: Big Ole AT's
2" lift.
Planned
Roof Light bar
Snorkle
Postby 4x4 bobby on Wed Feb 12, 2014 7:00 pm
Hey up Greg & Rob Deggie says thanks for the lights there great!
From me great service keep up the good work!!!!! :thumbup: :thumbup: 0
Postby gregster on Thu Feb 13, 2014 1:36 pm
rippa2k wrote:Hi,
Not at the moment I am afraid, and will be a couple of weeks probably before we look at getting another V6 in to strip...
Postby gregster on Thu Feb 13, 2014 1:37 pm
4x4 bobby wrote:Hey up Greg & Rob Deggie says thanks for the lights there great!
Cheers Bobby...glad they are pleased with them :wink: :dance:
Postby storesafe on Sat Feb 15, 2014 7:11 pm
Hi,
Just thinking of replacing the clocks for the olympus ones, have you got any and if so how much?
Oh I've got a 2002 3.2 v6 so think the DTi ones will work.
Ta very Much
http://s1122.photobucket.com/albums/l53 ... e149-2.jpg" onclick="window.open(this.href);return false;
Swillin' ale
storesafe
Vehicle Name: Gobbler
Modifications: New gauges fitted where crappy multi display was.
2" Suspension lift
Poly bushes all round
New Rough country shocks to front
Trooper springs on rear
Full Ice change
Olympus half leather interior
Postby gregster on Sat Feb 15, 2014 9:17 pm
Not at the moment mate, clocks for these cars are like rockinghorsepoo if they work...
Postby storesafe on Sun Feb 16, 2014 11:41 am
Yea I know, had mine repaired but they're acting up again.
Cheers for letting me know.
:thumbup:
Swillin' ale
storesafe
2" Suspension lift
Full Ice change
Postby storesafe on Mon Feb 17, 2014 8:46 pm
Hi,
I've removed the grill on my B series and lost the small wedge rubbers that fit on the wings just under the headlights/indicators. Do you have any spare? I also fancy a new grill so do you have a spare grill in midnight blue or black?
Many Thanks
Richard
Swillin' ale
storesafe
2" Suspension lift
Full Ice change
Postby gregster on Tue Feb 18, 2014 6:10 pm
Hi,
I will have a look for you, which grill does yours have? Is it the facelift B or the earlier one.
