// Frontera Technical Support • View topic - Detachable towbar (ball)
all adverts will be deleted after 21 days unless they are renewed
Postby red5 on Tue Jul 25, 2017 4:46 pm
Afternoon all. AM after a detachable ball section for a Frontera A Vx towbar if possible.
Cheers,
Sam
red5
Some dentage.
Re: Detachable towbar (ball)
Postby snapper on Tue Jul 25, 2017 9:34 pm
Do you have a knacked one or is it just plain missing?
Assuming it is knackered and you still have the original then check this thread out, they are repairable. Come to that, just check the thread anyway it may be of use....
Postby red5 on Tue Jul 25, 2017 9:35 pm
Its missing. Previous owner misplaced it...:-/
red5
Some dentage.
Postby snapper on Tue Jul 25, 2017 9:44 pm
Give Greg a call, he may well have one otherwise ebay is your best bet. They do come up on there.
I assume you have looked under the O/S Rear Seat Cushion? Just in case it's sat where it should be when not in use.... Also a good place to look for stuff in the scrap yards
Return to Frontera Parts Wanted
