// Frontera Technical Support • View topic - internet speed test
internet speed test
Re: internet speed test
Postby Gazeddy on Tue Mar 15, 2011 10:30 pm
beware those other network devices leech bandwidth too took me a few goes to get anywhere near my speed due to other network loads
Gazeddy
Vehicle Name: gazeddy
Postby James Bass on Wed Mar 16, 2011 1:32 pm
Just run another test after a lengthy conversation with my ISP.
I have been informed that the maximum my line can handle it 512kbps. On this basis, the 370kbps I'm actually getting isn't too bad, although I don't see why I should be charged the same price for "upto" 8 MEG as someone else who can actually get 8 MEG. Damn disgrace.
They've told me to run some additional tests with http://www.speedtester.bt.com 3 times per day for the next week, and call them back. Not sure if I have to record the results or if they're logged somewhere the ISP can access.
The results were :
Download Speed Achieved : 302kbps
DSL Connection Rate : 928kbps (DOWN STREAM) & 448kbps (UP STREAM)
IP Profile for line is 350kbps.
If someone could explain what the hell all this means, I'd be very grateful
MANY THANKS.
Postby BoxCleva on Wed Mar 16, 2011 1:35 pm
It means your local exchange is either a long way away and also more than likely contains antiquated equipment inside it.
Postby James Bass on Wed Mar 16, 2011 1:38 pm
So I'm knacked for getting anything better here, at least for the foreseeable future?
Postby jontera on Wed Mar 16, 2011 2:13 pm
i tried the test last night at home..just got a message back saying results are in the post, it'll get to you quicker.
Postby James Bass on Wed Mar 16, 2011 2:15 pm
:rotfl: :rotfl: :rotfl: :rotfl: :rotfl:
Postby James Bass on Fri Mar 18, 2011 11:00 am
Isn't it amazing what a complaint call to your ISP can achieve...
BEFORE...
AFTER...
Postby BadBoy on Fri Mar 18, 2011 2:02 pm
James Bass wrote:So I'm knacked for getting anything better here, at least for the foreseeable future?
Have you thought about switching to a 3G mobile network and using a dongle.
They could give you 2Meg+, but as always there's a downside. Depending on signal quality where you live you might have to use your pc in the garden to get a signal:roll:
Modifications: Looks a bit like a Kia Sorento 2.5CRDi Titian remapped for 265bhp!
Postby James Bass on Fri Mar 18, 2011 4:22 pm
I have a dongle (Orange) I use whilst at work. Unfortunately, the joys of living in a rural area mean I can only get a GPRS signal. :evil:
Postby ARMYOF1 on Fri Mar 18, 2011 6:52 pm
ARMYOF1
Model: 2.0i Sport Niagra 3dr
Postby reecy on Fri Mar 18, 2011 9:44 pm
22.65 download 3.44 upload and 19 ping. this is on a wireless laptop and will slow the speed down slightly but im supposed to be on 50 mb :shock:
Thanx, Andy
reecy
Vehicle Name: lean green pullin machine
Modifications: 255/65/16 road tyres on the car
and a set 235/70/15 mud terrains in the shed
removed the side steps
reverse sensors (removed)
30mm wheel spacers
Postby snapper on Sat Mar 19, 2011 4:35 pm
20 meg here
Postby mathan on Sat Apr 07, 2012 7:54 am
It depends on the Serer Location...You can take which is average..
My Downloading speed is 5.236Mbps and Uploading speed is 1.235Mbps.You can check the internet speed at Scanmyspeed.com I have checked at here.
mathan
Postby Bigga on Sat Apr 07, 2012 8:15 am
im with virgin and mine is constantly the same.....
http://speedtest.net/result/1880249204.png
Bigga
Postby adyclemo on Sun Apr 08, 2012 9:28 am
http://www.speedtest.net/result/1882022123.png
Not too bad. I am paying for 20mb unlike work who are paying for 30mb and getting on average less than 3mb
Regards Ady
Comment on the motor here
adyclemo
Full lenght roof rack.
Front tow bar.
CB.
Manual locking hubs.
Suspension lift.
32" BFG's
Snorkle.
Egr delete
Postby jonnyjeep on Sun Apr 08, 2012 10:44 am
iv just started with BT installing fibre internet and have a tester that shows actual download load speed and the potential of whats available, seen certain parts of belfast with the the potential of 140meg down and 60 odd up pretty mind blowing when you think off the dial up days
jonnyjeep
Vehicle Name: project20
Region: Northern Ireland
Postby andytats on Sun Apr 08, 2012 12:52 pm
bloody virgin i'm paying for 20mb :lol:
Postby James Bass on Sun Apr 08, 2012 4:19 pm
I wish I could get 7meg.
I know Talk Talk say "upto" 20 meg, but c'mon...
AND THIS IS A GOOD DAY!!! :shock:
Postby BadBoy on Sun Apr 08, 2012 4:52 pm
James Bass wrote:I wish I could get 7meg.
I have a 7meg line
Oh you mean download speed not upload :angel:
Postby James Bass on Sun Apr 08, 2012 4:54 pm
:butt: :butt: :butt: :butt: :butt:
